Spripped Crank!!!
Old Oct 14, 2005 | 09:58 AM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
Spripped Crank!!!
Okay okay, i know i know you cannot put a harm balancer on with just the bolt. I knocked it in as much as i could and I spripped it.
I tapped it out and got a new bolt. Still IFFY.
Now I need a fix that will last a year and it doesnt have to be removable. This engine is only a mock up and I refuse to replace the crank.
Weld the bolt on? JB weld i dont care it has to work though. for atleast a year.
Old Oct 14, 2005 | 10:10 AM
ede's Avatar
ede
if it's just a mock up i wouldn't worry about it at all. if you want a more permanate fix try a thread insert or going 1 size bigger, or next size bigger you can find a grade 8 bolt for.
Old Oct 14, 2005 | 10:11 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Helicoil
Old Oct 14, 2005 | 10:14 AM
Heli-Coil it.
JB weld will not hold.
Tapping the threads will not hold. Think about it.... you pulled the threads out; how can you "create" more metal back where you stripped it from, with a cutting tool?
Ever seen what happens to water pumps, alternators, radiators, etc. when a balancer comes off? Better yet, ever had to pay the bill?
Don't half-*** it. Heli-Coil is cheap and easy, and better than the original threads.
Then get yourself one of these http://store.summitracing.com/partde...art=CCA%2D4920 or the like from a parts store (I think even AutoZone has them), or make yourself one from some all-thread and a nut and a stack of thick heavy large OD washers, so you don't do it again.
{edit}hmmm.... that didn't do quite what I thought it would.... link says part # CCA-4920, window that pops up is something completely else..... look up part # CCA-4920
Old Oct 14, 2005 | 03:32 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
I never heard of this stuff it sounds good by reading the site. Can anyone tell me exactly what to order? I am not very good at determining screw sizes, and a brief description on how to install it. Thanks!
Old Oct 15, 2005 | 08:18 PM
SaintedCorrupt's Avatar
Car: '85 TA
Engine: Carb'd 350, ported 416s
Transmission: retrofitted T5
Axle/Gears: 3.42 7.62" 10-bolt, locker
i had a similar problem, but it was in the motor i was gonna use. i took it back to the machine shop, and they drilled the hole larger and tapped for a larger bolt.
but i agree, heli-coils are a great way to fix it quick and easy. way easier than the way i went about it.
Old Oct 16, 2005 | 09:12 PM
eric17422001's Avatar
Car: 3
Engine: inboard
Transmission: underfloor
What you need is a 7/16-20 heli-coil in the end of the crank. You may have to buy an heli coil set in that thread size but you don't have to take the engine apart and have the crank re worked to fix it.
Old Oct 17, 2005 | 10:37 AM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Yeah well, my airstation actually had some helicoil kits since we use it for the helicopters we work on. I was silly enough to use 7/16 14 instead of 20 but after retapping for 14 instead of 20 everything works good as new. Its funny really because the machine shop I called before you guys never even suggested this stuff. they said new crank, and that wasnt an option after the trouble i went through already.
Old Oct 17, 2005 | 10:51 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
They'd make a lot more money selling you a new crank and rebalancing than they would from putting a helicoil in.
Old Oct 17, 2005 | 03:31 PM
Car: 3
Engine: inboard
Glad to hear you got 'er fixed. When do we meet up and see what she's got? Shall I bring my S10 or my 305 Iroc?
Old Oct 17, 2005 | 09:27 PM
Vader's Avatar
The next time that happens, just retap it for 1/2-20 and get a new bolt. That's one of the beauties of the SBC design.
Falcon50
Aug 22, 2020 03:26 PM
RS Reaper
Oct 17, 2018 07:52 PM
skinny z
Oct 5, 2015 06:23 PM
anesthes
Sep 30, 2015 07:48 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
