283+350 cam
Old Nov 13, 2001 | 04:47 PM
GTA's Avatar
GTA
Car: 1992 GTA
Engine: running
Transmission: working
Axle/Gears: both
283+350 cam
Hi,
next week i am putting a 283 in my old truck
and i have a 350 cam and lifters from a
goodwrench eng from a previous project
is it too much cam for the small mouse?
eng is stock but it is +60 over and other wise
stock thanks later.......GTA
Old Nov 13, 2001 | 04:54 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
If the cam you have is the "929" cam with .390/.410" lift, it will work very nicely. A performer intake or maybe a weiand action+ with small tube headers would be a beauti combo for the street.
Old Nov 13, 2001 | 08:30 PM
GTA's Avatar
GTA
Car: 1992 GTA
Engine: running
Axle/Gears: both
Is this ## cast on the cam ?? If so Thanks
for the reply, When a small eng is givin
a larger displacement cam like i'm doing
will it react like a high perf cam rough
idle and all?? or will it be smooth and
good running like a stock eng should be?
--just curious .......GTA
Old Nov 13, 2001 | 09:43 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
That cam is the same exact pitiful thing that was responsible for mid-70s 350s having 165 HP. I have thrown those in the garbage and consider myself poorer to the tune of the garbage bag I ruined. It was also the stock cam in later 283s and 307s and 327s after about 65, and later 350s, especially the 2-barrel and low-perf 4-barrel ones.
It will work; but it will not be a performance-oriented setup by any means. If your 283 situation is a typical truck motor, it will be fine; just don't be expecting to set the world on fire.
If you want a suggestion for a better cam for the application, look at the Comp 12-208-2 265 "Dual Energy" grind. It should idle almost smooth, with a just barely detectable lope; but pull real hard through the midrange. It should give about the same gas mileage as the stock cam.
I agree with 88's intake and header recommendations. This cam should also work acceptably well with manifolds and a stock intake, but the improved induction will wake the motor up alot.
ICON Motorsports
Old Nov 14, 2001 | 06:14 PM
GTA's Avatar
GTA
Car: 1992 GTA
Engine: running
Axle/Gears: both
Thanks for the reply, the eng is going together with the "wimpy" goodwrench cam
but i have hope as it is just a runaround
truck,since the bores are punched out +60
does this give a big boost in compression?
hope it gives some, any bit is welcome
i will keep my fingers crossed........GTA
Old Nov 14, 2001 | 06:29 PM
82camaro's Avatar
Car: 82 camaro SC
60 over will add very little compression.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
masonta
Sep 1, 2015 06:40 PM
