Best hydrollic roller cam with afrs
Old Oct 14, 2005 | 07:52 PM
crazy3rdgen's Avatar
Car: 2002 SS
Engine: Ls1
Axle/Gears: 3:42 posi
Afr 195cc heads with 1.6 pro mag roller rockers
750 carb
rpm air-gap intake maybe
11:1 or 12:1 compretion
Stock bore and stroke
T56
3:42 posi
headers and exhaust
Going to go with an electric water pump if that will save some #'s.
I'm shooting for low 12's high 11's. I can't really find a bigger hydr roller then this xe282hr for sbc 350. I'm going to go with a high rev kit as well as a safe. What do you guys think?
I was thinking about going with the Xe282Hr from comp here's the specs, thing is i'll probably have to call afr and ask them what spring of theirs to run cause the spring comp calls for is like 1.430 o.d and the afr's spring pockets are cut at 1.450. So the springs that comp call for are useless.
http://www.compcams.com/Technical/Se...umber=08-432-8
Old Oct 15, 2005 | 11:07 AM
Car: 2002 SS
Engine: Ls1
Hotrodboba400
Dec 10, 2019 07:07 PM
Jorlain
Oct 8, 2015 01:57 AM
Strick1
Sep 4, 2015 07:11 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
z28guy134
Sep 1, 2015 11:50 PM
