vacuum pump on non boosted motors
Old Oct 15, 2005 | 01:24 PM
88_Import_Slaye's Avatar
Car: 88 Camaro
Engine: 310 LG4
Transmission: 700R4 w/2200 stall
Would there be a power benefit from using an electric vacuum pump on a non boosted motor? What about a high compression motor? like 10:1+?
I was reading in "Engine Masters" magazine they were talking about how they gained 20hp from adding a vacuum pump to their big **** motor, but it wasnt boosted.
Just wondering because I can retro fit a vacuum pump from a taurus which had an electric pump into my setup with ease, but dont want to do it if there isnt a benefit.
Old Oct 15, 2005 | 02:46 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Your not going to gain anything on a stock type motor. You really only need vacuum pumps to help seal low tension piston rings and keep a pressure buildup below the rings from forming.
Old Oct 15, 2005 | 05:08 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
ok here is a question for laughs.
if I took my airpump off my mazda hooked it up to my high mileage honda through the crank case vent would it maybe help seal the worn rings a little better?
would it give any difference maybe in gas mileage?
Old Oct 15, 2005 | 05:19 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
How does a vacuum pump seal rings better?
My take...more pressure on top of the rings would cause them to expand and seal, pulling vacuum (I assume from the crankcase) would cause the rings to "pull in" to the lands.
Any thoughts? Or am I missng the obvious?
Old Oct 15, 2005 | 05:50 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
something to do with a pressure differential.
higher pressure up top with the same pressure down low means a higher pressure differential between the two.
or you take the same pressure on top and lower the pressure on the bottom you get the same effects of a higher pressure differential.
Old Oct 15, 2005 | 07:03 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
That makes sense, more pressure on top, better seal, decrease the pressure below, does the same thing I guess.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
theshackle
Mar 5, 2017 06:37 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
86White_T/A305
Aug 17, 2015 12:16 AM
TreDeClaw
Aug 14, 2015 06:58 PM
