what grounds to the drivers side head?
Old Oct 16, 2005 | 01:44 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
anyone care to tell me which accessories are grounded via drivers side head in the rear ?
when i put my motor back together with new heads and cam i ddint bolt anything to the head cuz icould find the wires, but i know thier was something thier, im hoping thats my reason my car is flashing the check engine light and rpms dropping when i give it any gas under load.
Old Oct 16, 2005 | 03:58 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
IIRC, the ecms grounds go to that head, and probably the drivers side as well. Theres probably excessive noise causing issues with reading the memcal and such w/o those grounds.
Old Oct 16, 2005 | 09:36 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
mine has a big ugly ground strap on the passenger side head going to the firewall.
Old Oct 16, 2005 | 02:27 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
I don't have my manual here at school with me but I remember doing a ton of wiring in my car when I swapped motors. One of the grounds was for the windshield wiper motors I believe. I'm also pretty sure that the spark control module grounds there as well. What code is the ECM throwing?
Old Oct 16, 2005 | 02:29 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Fuel injector grounds too. There are 3 on the passenger side head and 1 big one totalling 4 and on the driver side I believe there is 2 grounds.
Old Oct 17, 2005 | 12:37 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
well i found the engine miss, the grund wire from my plugin ignition harness had come loose, but that does explain my wipers. everything else works fine including the enigne. dunno what else would ground to the DRIVERS side head.
Old Oct 17, 2005 | 12:59 AM
Car: 1997 Corvette
I can check when I go back home this weekend, but that won't be for a few days yet. What code is the engine flashing?
Old Oct 17, 2005 | 01:08 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
well it doesnt have any codes, it was flashing the light not long enough to store it. it was actually the iginition ground coming loose from my connector harness. not a real engine code.
Old Oct 17, 2005 | 01:20 AM
Car: 1997 Corvette
Are you having any other issues that need to be worked out, or are you jst curious as to what grounds to the driver's side head?
I'm pretty positive the wiper motor grounds there. There are two ring terminals in the back on that head from the factory (on my '88 anyways). Now that I think about it more, I do believe the other one is for the injectors on that bank. A lot of the grounds are inter-twined though, so the injectors may be getting grounded somehwere else as well. I'm sure there are other things that connect to the ground wires that go to that head too. Like I said, they are all intertwined and are a mess. I cut a lot of them away when I pruned my harness down (nothing important, just emissions controls, etc.).
I know the wiper motor ground is by itself though. Its a pretty thick-guage wire too. That leaves the other ring terminal to ground whatever else. I'm pretty sure the injectors are one, but like I said, they may get grounded elsewhere. The electronic spark module actually had a longer ground wire on it I believe, maybe going to the passenger side head.
Like I said, I can go through my diagrams and maybe some of my wiring when I get back home.
Old Oct 17, 2005 | 01:25 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
i would appreciate it i can only locate the wiper ground and if thier are other gr\ounds i cant find, i would like them to be secured as well to prevent future problems.
Old Oct 17, 2005 | 01:41 AM
Car: 1997 Corvette
Alright, like I said, I won't be home until Thursday, but I can check it out for ya when I get home when I go to wire in my MSD 6AL box
Old Oct 17, 2005 | 01:44 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
thanks i appreciate it.
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
Street Lethal
Aug 14, 2015 08:25 PM
timonator
Aug 11, 2015 09:56 PM
wruiz
Aug 11, 2015 02:59 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
