Removing valves
Old Oct 16, 2005 | 01:07 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Removing valves
Once I remove the springs, should I keep tabs on what valve goes where? I'm starting to port a set of cast L98's and add new springs and didnt know if i have to keep the same valve with the same hole. Also do the heads have to be decked to clean? I wanna make sure its true before I install. Motor and heads have 100+ Unknown amount on them.
Old Oct 16, 2005 | 01:46 PM
R1UK's Avatar
Car: Was 3rd Gen now MustangGT
Engine: 302
Axle/Gears: 3:73:1
Well its not absolutely essential , but the valves fit their guides, the valve fits the seat etc etc.
Personally i keep everything in its order.
If you were fitting new guides\valves\springs\ and cutting new valve seats, then no, of course not.
But it wouldnt blow the engine up if you did mix em.
Old Oct 16, 2005 | 01:56 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
It wont blow the engine up, but the valves wont seal either. You need to keep them straight if you're not doing a valve job or cutting the seats. As far as cleaning the deck you should have an engine shop check it out to be sure.
Old Oct 16, 2005 | 02:05 PM
ede's Avatar
ede
i wouldn't worry about it. never had a problem. but i'd suspect after you're done you'll want to recut the seats and face the valves. i like to have heads resurfaced as well as the block to help insure a good seal, but i've not had any problems not doing it either.
Old Oct 16, 2005 | 02:08 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Ok guys. Sounds good. Thanks
Cameeeero
Sep 18, 2015 04:00 PM
backtothe80s
Sep 5, 2015 12:39 AM
gixxer92
Sep 1, 2015 04:32 PM
NBrehm
Aug 25, 2015 11:49 PM
3rdgenparts
Aug 8, 2015 07:09 PM
