Blue smoke from my tpi
Old Oct 16, 2005 | 01:27 PM
tpidude1's Avatar
Car: 82 trans am,Project
Engine: lt1
Transmission: 4l60e
Axle/Gears: 3,27
Help...I have a l98 engine from a 88 firebird..I have rebuilt the engine and heads..I have new pistons and rings ..when I am driving downhills with no trottle the engine begin to smoke blue.. A LOT and when I have the engine to go on idle for a while and I rew the engine it smokes blue too...also when I stop the engine and wait five minutes and then start it up it smokes blue and smell burnt oil What is the problem??
Old Oct 16, 2005 | 01:37 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Could be worn valve guides/seals, the rings didnt seat, intake manifold didnt seal well.
Old Oct 16, 2005 | 02:04 PM
tpidude1's Avatar
Engine: lt1
Transmission: 4l60e
Axle/Gears: 3,27
If the intake manifold didnt seal well,wouldnt the engine idle bad?I have thougt at my valve seals and /or my piston rings that something could have happened when i put the engine together..Seems like the engine runs like a stock tpi would..oil pressure is a little low maybe? 18 psi at idle 500 rpm hot and at 50 miles in fourth gear(th700) 1400rpm ca 35 psi..42 psi at the same speed in third gear...
Old Oct 16, 2005 | 02:08 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
How was the engine broken in?
Do you have access to a compression or a leak down tester? Vacuum gauge?
Old Oct 16, 2005 | 02:13 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
oil pressure seems fine.
Old Oct 16, 2005 | 02:32 PM
tpidude1's Avatar
Engine: lt1
Transmission: 4l60e
Axle/Gears: 3,27
When I had my engine broken in I ran it wery fine for about 100 miles before I tryed to put the "petal to the metal" The engine did not smoke so much in the beginning i think,It seems like it smokes more now after ca 400 miles on it.. I am also using valvoline racing oil 20/50. When I am using a leak down tester,should the engine be hot or cold?
Red iroc-z 305
Sep 30, 2015 05:22 PM
Linson
Aug 21, 2015 02:12 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
