Cooling Fan troubles
Old Oct 16, 2005 | 06:04 PM
Slepewesel's Avatar
Car: 91 Camaro Z28
Engine: 5.0 TPI (LB9)
Transmission: 4L60
Hey guys. Car is a 91 Z, TPI. My cooling fan is wired into the ignition so it runs when the key is on. Supposed to anyway. Fan hasnt been coming on at all, so I figured the motor was shot since its about the only thing I thought it could be. Got a new motor, and same problem. If I wire it directly to the battery, it comes on. If I plug it in, nothing. I have 12v at the plug, and a good ground. Any ideas why this thing wont come on?
Brian
Old Oct 18, 2005 | 10:02 PM
Slepewesel's Avatar
Car: 91 Camaro Z28
Transmission: 4L60
Anyone ...?
Old Oct 18, 2005 | 10:56 PM
AnotherfastIROC's Avatar
Car: 06 Envoy, 84 Fiero, 86 Camaro
Engine: 4.2 I6, 2.5 I4, supercharged 355
Transmission: 4L60E, Muncie 4 spd, T-56
Axle/Gears: 3.42's, 4.10's, 3.73's
are you sure the plug to the fan has voltage/ground?
If so then is the plug actually making contact with the fan connectors?
Is the plug it's melted or in any way damaged?
Are you certain the + and the - are in the right places?
Are all the fuses good?
and lastly
Has the car recieved a proper exercism if none of that cures the poroblem?
z28joe2
Sep 28, 2015 05:54 PM
ndndndnd
Sep 28, 2015 08:00 AM
Lmancha96
Sep 25, 2015 08:11 PM
64goatman
Sep 9, 2015 01:09 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
