I cracked my intake manifold, HELP!!!
Old Oct 17, 2005 | 07:25 PM
Camaro91S's Avatar
Car: 91 Camaro RS
Engine: 350 C.I.
Transmission: 700R-4
Well I have a Performer EPS manifold and I was tightening down my fitting for the heater hose next to the thermostat housing and having a good time when I noticed it wasnt getting tight, so I look down and see a crack going down the threaded opening about 3/4". Tools went flying, yelled out a couple nice words then started thinking. . . How in the hell am I going to fix this??? J B Weld, Sauter??? What do yall suggest??
Old Oct 17, 2005 | 07:40 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Probably need to have someone weld it for you.
Old Oct 17, 2005 | 07:47 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
JB weld should work. Or possibly cooling system 'stop leak'
Old Oct 17, 2005 | 07:59 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Exactly how big is the crack? If it's big enough to prevent a fitting from fully seating when you screw it in, makes me think it's probably going to take a weld job. Not sure how JB weld would hold up.
Is there a warranty at all you can dink around with?
Old Oct 17, 2005 | 09:05 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
JB weld rules. JB weld the crack AND the fitting too... it'll never think about leaking ever again.
Old Oct 18, 2005 | 01:38 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
what on earth is Sauter? (oh please, oh please don't say what I think you're going to say, I swear i'll just off a bridge if the school system is this bad...)
epoxy would work too, it shouldn't be a big deal. If you're real keen, you could helicoil it.
Old Oct 18, 2005 | 01:47 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
He probably means "solder". I don't ever recall seeing the word in print in any of my years in public education in this country at least, so I don't know why you feel the need to comment on the state of the school system in his location. I don't know why you need to off a bridge either, what did the bridge ever do to you that you need to contract a hit on it?
Helicoils repair damaged threads, not split castings. They're not available in pipe threads anyway. I've never had much luck getting JB Weld to stick all that well to aluminum, and I especially wouldn't trust it to work in an application that's going to be stressed further by a tapered fitting and repeated heating and cooling cycles.
Old Oct 18, 2005 | 05:37 PM
Sonix's Avatar
Car: 1982 Trans-Am
Well, I feel pretty stupid then don't I?
ok Ape, since you seem to know what you're talking about, care to give a suggestion then?
Old Oct 18, 2005 | 08:01 PM
Camaro91S's Avatar
Car: 91 Camaro RS
Engine: 350 C.I.
Damn Sonix you must really enjoy making people feel stupid, appreciate that, I guess thats what the message boards are for.
I will figure something out, thanks guys.
Old Oct 18, 2005 | 11:22 PM
Irockz's Avatar
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
How about a picture?If it's fixable,and you'll pay shipping,I'll fix it for free.We can surely set up some secure way so you know you'll get it back.(Although I'm pretty sure that there's not been a string of people scamming cracked intakes on the net)
Post a picture,and check on shipping to 65617,if it's fixable,and shipping ain't stupid expensive,I'll weld it up for ya.
earlpote
Aug 28, 2015 10:42 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
theurge
Aug 21, 2015 12:46 PM
Jake_92RS
Aug 11, 2015 10:39 AM
