On a 4 wheel drive truck if the u joint breaks where the shaft connects to the hub wh
Old Nov 15, 2001 | 09:43 PM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
What will happen it is clicking real bad on the drivers side when the wheel is turn all the way and it clicks even when going straight. If breaks off at the hub can you still drive the truck? at least a little ways to get home. It is a jeep truck. 1990.
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Taylor Spiro-pro wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
Old Nov 15, 2001 | 09:58 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Let me ask you a question.
If you're in a forest standing next to a tree and it falls down, will it land on you?
Answer would be depends which way the tree fell.
Bets case you have a good break, and you can drive it forever, worst case is ut breaks, jams up in the spidle assembley, locks up that front tire from rolling, causes you to violently swerve to one side of the road, maybe into an oncoming car, over a cliff, into a telephone pole, etc...
So I ask you..which way will the tree fall?
Old Nov 16, 2001 | 06:11 AM
BLACK Z's Avatar
Car: 86 Z28
My luck it fall in the direction of a very large rig, or cliff. But if it does not get jamed the shaft will stop spining? it wouldn't spin even though it is connected to the front axle? I will fix it but I have alot of other things to do, I brought a houes I got my daily driver my third gen.And Since I may have to pay a shop a couple hundred bucks, it may have to wait.
Old Nov 16, 2001 | 09:27 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I replaced the u-joint on my brother-in-laws '79 4x4 (Chevy). The part was around 12 bucks, and took less than an hour, as i recall. Even if you tool it to a shp, it should be less than a $100.00 bill.
1992rs/ss
Jan 31, 2025 05:10 PM
midge54
Dec 27, 2019 04:14 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Reddeath210
Oct 6, 2015 08:20 AM
MENINBLK
Aug 5, 2015 11:58 PM
