Engine issues and questions
Old Nov 16, 2001 | 10:29 AM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
I have found an engine that needs to be rebuilt. The guy was running 8 PSI through it. He said that oil was spurting out of the dipstick. Now, i know this is not a healthy thing. Could this be cured by a simple rebuild or does it sound like more extensive damage?
Old Nov 16, 2001 | 10:57 AM
iroc5speed's Avatar
it seems to me that maybe the dipstick tube is just not sealed right. Try putting some permatex around where the dipstick goes in(take it out, put the permatex on, put it back in, let it sit for awhile to dry and cure). This should fix that problem, and if it doesn't then you preobably have bigger problems than that
'86 IROC 5-speed
305 LG4
edelbrock performer rpm intake
edelbrock 600 cfm carb
msd pro billet hei distributer
'95 3.23 rearend
hotchkis rear suspension
PST front polygraphite suspension
"speed kills. buy a f@&d, live forever."
Old Nov 16, 2001 | 11:30 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Could be it's got excessive blowby, probably just the rings are worn, boost going past them and pressure building into the crankcase.
Could be a hole in a piston(s).
But regardless of the problem, a tear down would be in order, as long as the cylinder walls are good enough to bore, there should be no issues with a rebuild.
Old Nov 16, 2001 | 11:37 AM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
Yep, major blow-by is probably the culprit.Last car I had with oil pumping out the dipstick tube was because #7 piston had pinched top ring (detonation) which ended up creating a hole in the piston.All that pressure has to go somewhere.
-Rich-
Old Nov 16, 2001 | 12:13 PM
Omega's Avatar
Engine: LS1 / LS3
Thats what i thought. Thanks for the comments... now to pick the block up!
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
