Pully's
Old Nov 15, 2001 | 10:07 PM
Trent257's Avatar
Pully's
Should i get some under driven pully's, all i will need it my crank, alt, and power steering pump, maybee water pump, how much hp do they add, and what are some nice chome or polished ones
Trent
---Car---
89 Firebird/305 L03 TBI A4/t-tops
Open Element Edelbrock Aircleaner w/ K&N air filter/Summit Chrome Valve Covers
Edelbrock TES headers 3" out/flowmaster American thunder 3" exaust/Catco cat
---Stero---
Pioneer DEH-P730 Premium
Infinity 2way 4652 4x6's/Pioneer 4way ts-a6985 6x9's
profile cl640 110x4
Old Nov 15, 2001 | 10:17 PM
Alan84TA's Avatar
I just got a 3 piece set from March. They were $225 for my L69... I've heard both good and bad so I decided to get them and try it for myself... I got a big "seat of the pants" difference. I'm happy with them. I'm going to take it to the track Sun. and see how much I gain.
Old Nov 16, 2001 | 07:10 AM
MARKT111's Avatar
Car: 1989 TTA
Engine: 3.8 Turbo
Transmission: 200R4
DON'T DO IT !!!! nothing but charging problems,no gain,going to remove mine
Old Nov 16, 2001 | 09:31 AM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
If you aren't charging well enough, March makes new "Power & Amp" Pulley sets that reduce accesory rpm's, except for the alternator,which is increased.Good for people that want underdrive pulleys, but have a big stereo(like me).
2 piece black set is $92.99
3 piece polished set is $173.99 from Jeg's.
-Rich-
Old Nov 16, 2001 | 11:00 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I find it hard to belive you could feel a SOTP difference with them.
On Lingenfelters site, they have engine (not chassis) dyno results with the March pulley setup, IIRC, there was between 3-5HP increase toward the very topend of the curve. Figure drivetrain loss, and it'd be less at the rearwheels.
Regardless, every little bit helps when you're trying to gain just a scooch more, and they do look much better than the stock pullies.
Old Nov 16, 2001 | 02:24 PM
Joel Geerling's Avatar
Car: 91 Formula
Engine: 305 TBI
You can get a 2 pulley (crank and alt) Mr. Gasket set that's just as good as the March ones for under $80. I think the place I got mine was carpartsonline.com. They're not a complicated set of gear...
Don't worry about the alternator charging voltage unless you have something sucking a lot of power, like a big stereo. Yeah, your headlights dim a bit at idle (and your battery gauge will drop to the 12-13 range from 13.5+), but it shouldn't hurt unless you have a stereo.
Pulleys are cheap and super-easy to put on (remember, you'll need a new belt, tho - search the boards for the part # or measure with string when you're ready for it), but I wouldn't do them as a solitary mod expecting to see a huge gain. With pulleys, an open element, and a TBI spacer (and everything else well-maintained), I'm measuring about 15 hp more (with a G-Tech) than when I bought the car bone-stock.
Oh, yeah - the crank is the big one to underdrive (putting on a smaller crank pulley slows the whole belt system down), the others (making alt, waterpump, smaller) don't make as big a difference... wouldn't worry about spending the xtra $$ on the 3-pulley set, but that's just my opinion, it could be wrong!
Joel Geerling
Red 91 Formula, 305 TBI
Edelbrock 14x3 open element
TBI 1/2" spacer
Hypertech street chip
Crank/Alt Pulleys
Exhaust is next!
[This message has been edited by Joel Geerling (edited November 16, 2001).]
bryaniskoo
Oct 1, 2015 03:18 PM
sunbound
Sep 5, 2015 11:52 AM
89_G92_Iroc
Aftermarket Product Review
Nov 23, 2001 02:07 AM
cobrakiller1989
Sep 30, 2001 08:56 PM
curt86iroc
Aug 7, 2001 12:03 AM
