Changing fuel filter
Old Oct 18, 2005 | 02:06 PM
ponykiller1992's Avatar
Car: 89 formula 350
Transmission: Stock 700r4
I am gonna change the filter in my iroc to be on the safe side. I know that there is pressure in the line. How do I release it, or is it even worth doing? Also, any little tips to make this job easier?
Old Oct 18, 2005 | 03:02 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Pull the fuel pump fuse, then start the car. It will die after a few seconds then the pressure is gone. There is still fuel in the lines so expect alot of it to drain out when you loosen the filter. Easy 30 minute job.
1992 Trans Am
May 10, 2023 07:19 PM
jklein337
Sep 19, 2018 06:23 PM
Infested
May 22, 2018 11:56 PM
Logan Bryant
Aug 27, 2015 11:52 AM
92camaroJoe
Aug 13, 2015 06:07 AM
