Ok so check it out i switched my stock coil for an Accel performance coil part#140011
it runs fine up to about 35mph but after that or if i gun it it starts feeling like its starved for fuel and then starts backfirering and engine gets really hot, so i switched the coil out with another accel coil and it still did it, put stock coil back in now its running normal. pls help
92rs
new 305TBI cratemotor
K&N
Helix power tower(tbi spacer)
flowmasters
no cat(piped over)
street&performance elec. chip
open element air cleaner
removed hood seals.
"I live life a quarter mile at a time eatin fords and ****tin ricers"
92rs
K&N
flowmasters
no cat(piped over)
removed hood seals.
Did you wire the coil backwards? Try switching the + and - connections.
-Tom P (Hot rodded 1986 Firebird 2.8l)
no its not possible to wire it backwards the clips will only go on one way
92rs
K&N
flowmasters
no cat(piped over)
removed hood seals
taylor pro ignition wires
removed AIR equipment
"I live life a quarter mile at a time eatin fords and ****tin rice"
92rs
K&N
flowmasters
no cat(piped over)
removed hood seals
F-BIRD'88
close
That coil looks like a capactive discharge type coil. Your stock system is inductive discharge type.
[This message has been edited by F-BIRD'88 (edited November 16, 2001).]
