NTP sealing?
Old Oct 21, 2005 | 01:00 PM
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
NTP sealing?
On fuel systems do you use anything to seal NTP fittings? I know that AN fittings don't use anything. Thanks.
Old Oct 21, 2005 | 01:01 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Its NPT (national pipe thread)
I use some fuel safe thread sealant or teflon tape.
Old Oct 21, 2005 | 01:15 PM
Engine: LS3
oops, my mistake. Thanks. Ok teflon is what I was making sure would work. Thanks.
Old Oct 21, 2005 | 01:56 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
fittings that use the THREADS to seal, use teflon tape or paste.. dont use tape on anything that might be damaged if a piece goes into the system (nitrous systems, fuel systems, ect)
if the fittings use a seating surface to seal, such as flare fittings, AN fittings, ect.. do NOT use any form of sealant on the threads.
if the fittings use a Oring seal, just make sure the ring is oiled before putting the fitting in.. do not seal the threads.
Old Oct 21, 2005 | 02:05 PM
Engine: LS3
So then paste on all the fuel system stuff i guess. What is the best paste?
Old Oct 21, 2005 | 02:09 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
i like the PERMATEX stuff the best myself...
http://207.19.195.113/products/prodi...&item_no=80631
the pic there is of the tube.. i usually get the little bottle with the brush built into the cap.
Old Oct 21, 2005 | 02:51 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Permatex thread sealant with teflon here, too. It's good stuff.
Old Oct 21, 2005 | 03:08 PM
Engine: LS3
How about on N2O lines too, and solenoids? I got a kit used, but the guy that had it before did a good job sealig but an ugly job. I want to take it apart and do it again cleanly.
1Aauto
Sponsored Vendors
Oct 19, 2016 08:50 AM
1Aauto
Sponsored Vendors
Oct 13, 2015 03:06 PM
