Is this small deck flaw going to hurt me?
Car: 94 Camaro
Engine: 380 sbc
Transmission: th400
Axle/Gears: 9" 4.11
I picked up my 406 assembled short block awhile back, and didn't notice this tiny flaw in the deck until I got home. I dont' think it should hurt anything due to where its located. It's pretty shallow, I can just barely catch my fingernail on it. What's your opinions? I really dont want to tear this thing apart to deck it.
Car: 86 IROC, 89 GTA
Engine: 350 blocks, both of em
Transmission: 700r4s
Axle/Gears: 10 bolt and 9 bolt, 3.73, 3.23
wow it would be nice to know how that happened. Not good. you could possibly get some cracks around there so i would watch out for that.
Car: Was 3rd Gen now MustangGT
Engine: 302
Axle/Gears: 3:73:1
Its not nice, but ive had to put together worse, only coz people often dont want to know, when you tell them how much to get it dead right.
But touch wood none have ever gone wrong, depends a lot on if you are going to hammer this motor?
Its easier to repair now tho, before it goes in.
Car: 94 Camaro
Engine: 380 sbc
Transmission: th400
Axle/Gears: 9" 4.11
The short block is brand new, was a virgin gm block, so this happened when the block was still "stock". I am going to give this motor a little heck, but its not going to see any street use, trailer it to the track, race, tailer home.
Car: 94 Camaro
Engine: 380 sbc
Transmission: th400
Axle/Gears: 9" 4.11
Where can I get turcite? I did a quick google of it, all I could find were bar stocks of solid turcite.
Thanks for the help!
I used to be able to get that in pourable resin/hardener. I'll have to check sources at work. Your other options would be bronze putty/scraping, brazing the void full and machining it flat, or welding the void with a nickel filler material, then machining.
Frankly, the void looks small enough and in a relatively low stress area, and may not cause any problems.
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Originally posted by Vader
I used to be able to get that in pourable resin/hardener. I'll have to check sources at work...
I'm so paranoid though, and hate re-doing work I don't have to, that I would fix it... if it were my block anyway...
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Looks like a casting void or some other defect. Maybe corrosion? If its a defect that occured during casting, its sort of ominous as there could be more hidden in the block. Anyway, if it was the only thing bad about the block, I wouldnt loose any sleep over it. Its not near anything really critical sealing wise and appears to be pretty shallow.
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
that spot in the deck is not going to cause you any problems.
It is not near the combustion chamber edge or near a water hole.. Probabily been there since day 1.
I would not try to fill it or anything. just assemble the motor and forget about it.
Car: 1988 Trans Am GTA
Engine: 350 4BBL
I agree with F-bird. It's a casting flaw and where it is it won't cause a problem. Decking it would turn a non-problem into a non-fixable problem. Sure hope those are forged pistons, there is some major clearance between it and the bore going by the pic.
~giving him something new to worry about~
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
If you are building a highh end motor you'll probably want to zero deck it anyway, and that should take care of it. I'd magnaflux it as well just to be safe.
Car: 94 Camaro
Engine: 380 sbc
Transmission: th400
Axle/Gears: 9" 4.11
Block has been magnafluxed and checked out ok. So f**k the flaw and just assemble the rest of it, sounds good to me!
I trust the people that did the machine work, and assembled the short block, they're a pretty big race shop here in Iowa. No, they aren't forged, I think the small radius at the top of the piston and the lighting makes it look like a bigger gap in there.
gta892000
Sep 16, 2015 12:37 AM
