Just scanned my car
Old Nov 17, 2001 | 09:16 PM
9177's Avatar
Just scanned my car
Just scanned my car, it shows that I have a low battery condition on startup, but it displays I'm running at 13.9 volts. Could this cause startup problems and also is this normal and how would I fix it if it is not?
Old Nov 17, 2001 | 09:39 PM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
After the car is running the alternator starts doing it's thing giving you the 13.9 volts (shows it's charging the battery). I'd say perhaps your battery is getting weak or you have some bad connections. Yes it can cause problems on start up. The ECM and associated components need proper voltage.
Rob P
89RSconvtZZ4TPI Edelbrock Intake
SLP Dual Cold Air Intake 1 5/8" Headers Semi-Siamesed Runners, IROC
suspension, alum shaft. Numerous mods.
92Z28convt5spd (stock)
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Old Nov 18, 2001 | 06:20 AM
9177's Avatar
I am using diacom and it shows that i have a charge of no less than 12.3 volts at all time but for some reason it says i have a low power condition. I assume this is just power to the ecm, Which pins and wires should i check?
Old Nov 18, 2001 | 08:29 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Is this an SES code you are getting? If so, there is no SES code for a low battery condition on a Thirdgen ECM - just high voltage.
There is a Low Voltage SES condition for the Fuel Pump.
Old Nov 18, 2001 | 01:28 PM
9177's Avatar
No one of the data postions on diacom says "battery status" which only sometimes reads low when i first start the car and another data postion says Voltage which after the car starts is imediatly 13.9-14.1. This is with the diacom program and I forgot to mention its on a 91 305 TBI. Hope this clears up everything.
Old Nov 18, 2001 | 02:18 PM
Car: Death Mobile
Engine: 666 c.i.
Sounds completely normal and logical. If you have your scan tool running (without the engine running), it will show a lower voltage than if the engine is running. When you are first cranking the enigne, you have one of the heaviest electrical loads running off the battery and will get a lower voltage reading. Once the engine starts, the voltage will increase because the alternator is now providing power.
You don't have any problem.
Old Nov 18, 2001 | 02:31 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
During cranking, voltage can drop as low as 9.5 volts, since the starter is pulling over 200+ amps. This is normal. As long as "at rest", the battery is around 12V (11.5-12.5) and engine running, its 13+
If you live in Southeastern US, check us out!
South East Thirdgen
1987 Trans Am 305
14.88 @ 92.81
Old Nov 19, 2001 | 09:25 AM
9177's Avatar
it usually does it for atleast a min after starting and it only does it when the car is warm
Old Nov 19, 2001 | 10:00 AM
9177's Avatar
thanks everyone for your help. I found the problem the guy before me hard wired the fan with the ecm and had not one but two inline splice connector which left the wire so weak when i was unrappin the tape it busted. anyways thanks for the info
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
