Comp Cams Belt Drive "Wet System"?
Old Nov 18, 2001 | 10:50 PM
Scott_92RS's Avatar
Car: 1992 RS
Engine: 406 Stealth Ram
I have an opportunity to pick up a belt drive timing system for pretty cheap. Can someone tell me what makes the "Dry System" more expensive than the "Wet System"? Is the "Wet" system safe to drive on the street? Thanks guys.
Old Nov 19, 2001 | 12:08 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The "dry" version has more parts than the "wet"; think about it, there have to be 2 oil seals with all the machine work to go with them, etc....
If I had a choice I would go with the dry one. But I see no reason that there would be anything wrong with the wet one on the street, especially if you could get it for cheap.
ICON Motorsports
Old Nov 19, 2001 | 09:11 PM
lexussc94's Avatar
I ended up sending my comp cams wet belt drive back, after I found out that the belt should be replaced every 500miles.
Old Nov 19, 2001 | 09:27 PM
Scott_92RS's Avatar
Car: 1992 RS
Are you sure? I'm going to call Comp Cams tomorrow to verify this. Thanks for letting me know.
Old Nov 19, 2001 | 09:28 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
These belt drive systems are race only stuff
and will not make your car faster or better.
they will never last as long as a stock
timing chain and gearset. A big waste of money. I'd pass on it.
Frozer!!!
Jan 19, 2024 04:55 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
gta90
Sep 15, 2015 04:00 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
TreDeClaw
Aug 14, 2015 06:58 PM
