92 Water Pump
Old Nov 19, 2001 | 11:17 PM
bensonortho's Avatar
92 Water Pump
Does a 92 350 with a Serpentine belt use a short style pump like the late 80's Corvette or a long style like other passenger cars and light trucks (both reverse rotation)? Where does the heater hose return connect(pump or radiator)? Also looking for Stewart part #'s for this application.
Thank you.
Old Nov 20, 2001 | 09:47 AM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
92 Serpentine is Long-Style Reverse Rotation.
Heater hose return connects to radiator.
Stewart Components Stage 1 Part#13123 $69.95
Stage 2 Aluminum Part# 23123 $149.95
Stage 2 Polished Aluminum Part# 23123HP $264.95
-Rich-
Old Nov 20, 2001 | 11:48 AM
thank you for the info . I have a good radiator shop that will add the heater hose fitting to my radiator for about $15, and this will also help reduce the clutter at the front of the engine.
Thanks again.
evilstuie
Jan 9, 2020 08:29 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
RyanJB
Sep 2, 2015 01:27 PM
Dialed_In
Aug 20, 2015 01:45 PM
