Lifting Front Tires
Old Oct 25, 2005 | 07:12 PM
84RIceEater's Avatar
Car: 84 Camaro. 90 integra
Engine: LG4, 1.6 (402hp)
Transmission: 700r4, JDM ITR w/ kaaz LSD
Lifting Front Tires
I was Wondering whar Hp/TQ rating and weight you guys have that will lift your tires off the Ground. Just Wondering. i will be making around 450 w/ some weight reductions, and slicks.
Old Oct 25, 2005 | 08:04 PM
1983Fbody's Avatar
Car: transam, el camino
Engine: 415
IIRC I think 500hp is about the minimum what you need with a well tuned suspension and a sticky/skinny combo.
Old Oct 25, 2005 | 08:09 PM
yeah that is what i was thinking 500-600 Hp Range. dang .. WOuld Be kinda Cool to do
Old Oct 25, 2005 | 09:26 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
Obviously not trying to win any races with that logic
Old Oct 26, 2005 | 02:35 PM
N8MAN1068's Avatar
Car: 85 ta ws6 KITT
Engine: Lb9
Transmission: th350
I think HP is going to be irrelevant, since you'll be going from a dig.
TQ+traction would be what you're looking for.
What that # is, i don't know.
Old Oct 26, 2005 | 02:50 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
you can do it with less then 400hp at the wheels.
there are ALOT of stock internal LS1s pulling the wheels at the track.
the key is NOT the motor.
the keys are traction, weight, and suspension.
to yank the wheels as quickly as possible: (or atleast pull the drivers wheel)
slicks.
skinnies. (40+ lbs of weight is nothing to sneeze at)
big stall(auto) or deep gearing.(manual)
drag struts/shocks
drag springs
basic weight reduction
if you're not pulling them yet, you're damn close.. you could continue with a shorter TQ arm for a harder hit on the tires.. more weight off the nose, ect.....
and of course, theres always more power.
Old Oct 26, 2005 | 04:03 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
If one were so inclined they could calculate the force required to do it. Then you could figure out the torque that the tires must apply to do it. But i'm not so inclined to do right now....
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Dialed_In
Aug 20, 2015 01:45 PM
aaron7
Exterior Parts Wanted
Aug 18, 2015 05:47 PM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
