Changed oil, tried to start car, bad noise!
Car: 1992 Camaro RS, Teal
Engine: 305 TBI, Soon to be 383 HSR
Transmission: Pro-Built 700R4
Okay, I changed my oil today. Drained the oil, watched TV for about 30 minutes, then came back, put the plug and the filter back in. Filled it back up with 5w30 valvoline SynBlend and an additive (some blue kind). Tried to start that car back up. BAD NOISE! Ping/knock/not good. shut it back off. Tried it again, engine did the same thing. Dad won't let me start it again until we work on it tomorrow. Any ideas?
Car: 99 Formula
Axle/Gears: 342
First of all, I wouldn't have put that additive in there. Most people will tell you to stay away from additives. I'd make sure you got the right oil filter or check to make sure the gasket off the old one came off. Sorry I don't have any other suggestions.
"Putting any amount of money into a RICE BURNER is like wiping your a$$ with a turd. "
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat, just switched to 180* b/c of winter coming and going to college in the mts.
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
'86 IROC
GM GOODWRENCH 350
KN AIRFILTER
3:73 Posi
Rebuilt 700R4
Often, it's because something was dropped into the oil-filler hole, and is rattling around the rockers. I'd recommend pulling the one valve cover. Better safe than sorry.
If nothing is missing from underneath the hood, like a wingnut or bolt, then maybe that's not it.
No guts, no glory.
No guts, no glory.
Car: yep
Engine: uhuh
Transmission: sure does
How long did you let it run??
Its not uncommon to have a motor knock for a few seconds until the dry oil filter fills with oil and it all gets circulating.
Thats why its a good practice to fill the filter first.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
"He can see air"
I let it run for about 10 seconds the first time and then about 15 seconds the second time.
Car: 83Z28 HO
Transmission: G Force 5 speed
First thing I would look at is the oil pressure. If you're at 40 psi or above on a cold engine, that's normal. Then I'd say check the filter, then under the valve covers.
-1983 L69 Camaro Z28 305 H.O. (Bored .030 over,Teflon oil seals,Melling H.V. oil pump,Hyperetic pistons,chrome-moly rings,2040 Crane compu-cam) T-tops, 3:73 Open rear, BW T-5, Rebuilt E4ME 4 Barrel, Duel Snorkle Air Cleaner w/K&N Filter , Rhino Clutch, Crane 2040 Compu-cam, LS1 valve springs, porting, PST front end kit. Now for paint, interior, etc...etc.... Also:
2000 S10 4.3L 4WD LS
1995 Ford Thunderchicken, 4.6 V-8
Is it a random noise, or does it come in regular intervals, like one lifter or one cylinder is making the noise? I let my oil drain a long time once, as you did, and I had a lifter tick after I put the new oil in ! But the tick went away after a few hundred miles.
88 GTA 5.7 TPI Charcoal Grey Bone Stock except for loose muffler which makes it a bit louder
than normal.
than normal. Trending Topics
Took it into the local Chevy dealer. Somehow the oil pan got crushed by the steering arm and the crankshaft was hitting the oil pan. I could've sworn that I lifted the car by the frame. Oh well, my dad's flipping the $800 bill. Thanks anyways guys.
Car: yep
Engine: uhuh
That will do it.
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
"He can see air"
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
"He can see air"
Car: 99 Formula
Axle/Gears: 342
I guess my Dad shouldn't be mad then at the time I took out the fixture screws on the headlights of my Mustang and he had to fix it.
'86 IROC
GM GOODWRENCH 350
KN AIRFILTER
3:73 Posi
Rebuilt 700R4
'86 IROC
GM GOODWRENCH 350
KN AIRFILTER
3:73 Posi
Rebuilt 700R4
Car: 1986 Firebird
Engine: 2.8 V6
Yeah, that should lessen his anger...
Mutiny, does that price include a new center link and alignment?
[This message has been edited by TomP (edited November 20, 2001).]
I sure hope so, my alignment was perfect. That's great for a car with 140,000 miles on it. they checked it when I got new tires about a month ago.
maroe624
Apr 16, 2017 08:29 AM
db057
Aug 11, 2015 10:11 PM
