Would these specs get me in the 11's
Old Oct 27, 2005 | 03:07 AM
mcbchild's Avatar
Car: 1984 Firebird SE
Engine: 388 sbc, Brodix Track 1s
Transmission: turbo 350 transmission
Axle/Gears: 4.10 gears
Having 387hp @ 6000 rpms and 385tq @ 4500 rpms. Mind you i guestimated 10.5:1 compression and a full exhaust system.
Old Oct 27, 2005 | 04:54 AM
ede's Avatar
ede
not enough info, like weight, 60' time, traction, etc
Old Oct 27, 2005 | 09:37 AM
mcbchild's Avatar
Weight is listed in my sig and rear tires are also listed in my sig. Don't have any 60' times yet.
Old Oct 27, 2005 | 07:56 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
If thats RWHP, then its quite possible. I know someone who made 365 RWHP on the dyno over the summer, and he's dipped into the 11's a couple times.
Old Oct 27, 2005 | 08:05 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Those are DD2000 numbers. So no, you won't be able to do it in a car that heavy.
Old Nov 3, 2005 | 08:01 PM
bitchin85camaro's Avatar
Car: 85 camaro
Engine: 327
Transmission: 350, 6200 stall, w/ brake
Axle/Gears: soon to be strange 5.14
11's
maybe not 11's but should make for some nice 12 second times. but just wondering, have you raced the car before?
Old Nov 4, 2005 | 10:50 AM
mcbchild's Avatar
Re: 11's
No, haven't raced yet. I just feel that something is wrong with my setup. Used to pull hard to 6000 rpm and now, I don't have the pull any more and engine is breaking up bad around 5800 RPMs. Tested fuel pressure at WOT and is consistant 8 psi. Carter Race fuel mechanical pump. Changed plugs, wires and dizzy. Still no help.
Old Nov 4, 2005 | 05:57 PM
zz17iroc's Avatar
Car: 91' Z28, 92' Z28
Engine: 383, L98 stock
Transmission: Built 700R4, Stock 700R4
Axle/Gears: 12 Bolt 3.73, 10 Bolt 3.23
I see you are using a flat tappet cam. If you where running alot harder before, you may have whipped one or more cam lobe(s)?.
How old is the engine?
Old Nov 5, 2005 | 08:41 PM
mcbchild's Avatar
Engine is only about 1 yrs. old this month and only has around 800 miles on the engine.
Old Nov 5, 2005 | 08:49 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Re: Re: 11's
Valve spring pressure is laying down on ya.
gord327
Oct 3, 2015 01:25 PM
mfp189
Sep 27, 2015 09:25 AM
wstephan96
Sep 25, 2015 04:28 PM
TX-SleeperC5
Sep 24, 2015 03:13 PM
angel2794
Sep 8, 2015 06:22 PM
