416 heads, 1.50 vs 1.60 ex valves
Old Oct 27, 2005 | 05:33 PM
88_Import_Slaye's Avatar
Car: 88 Camaro
Engine: 310 LG4
Transmission: 700R4 w/2200 stall
I see a lot of people not going to 1.60 valves on the 416 heads, they are staying with the 1.50. By going to a 1.60, what is the difference going to be vs a 1.50 valve? Is it even a question worth asking?
Old Oct 27, 2005 | 05:42 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
In a nutshell, more valve = more area to flow through = better. Factory heads from this era needs all the exhaust help they can get.
1.94/1.6 valves are what I used in my P/P'd 416's.
Old Oct 28, 2005 | 01:18 AM
REALPOWER's Avatar
Car: 1984 Camaro on steroids/ 1987 iroc-z28 5 speed.
Engine: 383 nitrous motor / poindexter 305
Transmission: Th350
Especially for a high exhaust breathing motor such as a nitrous or blower motor.
Old Oct 29, 2005 | 10:31 AM
Car: 88 Camaro
Engine: 310 LG4
what about port velocity? someone else said they used smaller valve for port velocity
Old Oct 29, 2005 | 10:45 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
You worry about port velocity a lot more on the intake side than the exhaust. Factory exhaust ports need all the help they can get.
The exhaust side is more or less shoved past the valve. Rather than the intake, where if there is too much oprt volume, the incoming air charge can "deaden" (lose velocity) because the port volume is too large. Exhaust exits the past the valve first. There's really nothing to lose velocity over.
Old Oct 29, 2005 | 06:01 PM
Vader's Avatar
As long as you can squeeze them in without shrouding or clearance issues, go bigger.
I've generally been an advocate (check the archives) of using larger valves and less lift to achieve flow. You can always open the larger valve wider if you want. More valve face perimeter area will generally provide more flow than opening the same valve wider.
Old Oct 31, 2005 | 03:16 AM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
And choose a dual profile cam with extra lift and duration on the exhaust eccentric.
gta90
Sep 15, 2015 04:00 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
89mulletbird
Aug 12, 2015 07:08 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
