RUn the ODOMETER forward??
Old Nov 20, 2001 | 05:13 PM
un4givin89's Avatar
I don't want to roll it back. I just got my state inspection and the DMV has it recorded as 104,615.2. But I have a broke speedo.
So I bought a new 145 MPH speedo off of ebay. It reads 65,454.6. How do I run it forward? I just want to set it to the same as the other. Or can i take out the odometer parts, without messing up my needle??
un4givin89
Old Nov 20, 2001 | 05:33 PM
un4givin89's Avatar
nevermind I think I figured it out using a dremel on my old speedo
Old Nov 20, 2001 | 06:39 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It's easier just to move the odometer from one to the other.
Old Nov 20, 2001 | 07:20 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
You may burn the drme up before you get close.
Might be worth a trip to an Auto-Electric shop and have them set it for you.
Old Nov 20, 2001 | 09:05 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
<font face="Verdana, Arial" size="2">Originally posted by un4givin89:
nevermind I think I figured it out using a dremel on my old speedo</font>
Yea that works great. I use a drill to reset my speedo's when I install a new engine. Of course iplan on keeping my cars so it's not a serioius crime
ssc
Old Nov 21, 2001 | 10:25 AM
86-red_dawg's Avatar
i had the same problem, but with a little looking around at the 145 speedo, it's not that hard to slightly take apart, and then you can manually roll each number to the right place, and doesn't take 43 hours to turn that many turns ;-)
Old Nov 21, 2001 | 10:02 PM
un4givin89's Avatar
now i broke the ****er, It isn't as easy as you home slices claim. There's got to be a better way.
Old Nov 22, 2001 | 01:34 PM
88camaro's Avatar
the way i did mine was connecting a small motor to the speedo cable running to the transmission and let it be for a time
worked fine, and nothing broken .
the motor was a small electricall motor with a 9 volt battery.
hope it helps
Vintageracer
Jan 10, 2020 05:33 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
mizz0313
Aug 12, 2015 06:45 AM
kyle5647
Aug 7, 2015 03:08 PM
