what should i torque the spark plugs to???
Old Nov 22, 2001 | 11:49 AM
breathment's Avatar
for engine is sig, what should i torque them to?
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series Muffler added to Unkown CatBack, Ported Intake
http://www.geocities.com/david_angel_16
Old Nov 22, 2001 | 12:59 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
The specs are in German - Guten-tight. hehe
Seriously, a torque wrench is not needed for spark plugs. Get them fully seated and apply enough pressure to make sure they will stay that way. Just don't try to stand on the ratchet handle to torque them down..... If you are worried about them not wanting to come out when the time comes, add some Anti-Sieze to the threads of them and they will spin right out upon removal.....
1987 GTA L98 MD8
355, TFS Heads, LT4 Hot Cam
My GTA
The Minnesota F-body Club
Old Nov 22, 2001 | 01:08 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Always use anti-sieze and just install them snug.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
Old Nov 22, 2001 | 01:41 PM
ede's Avatar
ede
if you have aluminum heads i'd use a torque wrench and anti seize
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
evilstuie
Feb 28, 2016 03:33 PM
LittleFranks
Sep 17, 2015 12:22 PM
tricky1
Aug 23, 2015 01:17 PM
g.l.mos
Aug 22, 2015 12:02 AM
