locktite
Old Nov 1, 2005 | 09:37 AM
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
locktite
OK. I am wondering what kind of locktite, if any to use on many things.
-Pressure plate bolts
-Bellhousing bolts
-flywheel bolts
-valve cover studs
-carb studs
-water pump, crank pully bolts
I think you see where I am getting at. Do you use locktite on most things, or just on important things that need to not budge.
Also how do you know how much to toque these things to?
Thanks guys, I ask cuz i am picking up my 383 today thanks.
-Dennis
ps-what size bolts do you use to bolt your motor mounts to a PA K-memeber? Thanks again
Old Nov 1, 2005 | 12:51 PM
Engine: LS3
please help if u can. I am gonna be using info that I learn here within the next few hours. Thanks.
ttt
Old Nov 1, 2005 | 01:02 PM
ede's Avatar
ede
red is all i use or what'd use, or what i have used in the past for all the applications you listed.
Old Nov 1, 2005 | 01:24 PM
Engine: LS3
nice. thanks.
Anyone else have input on this issue?
Old Nov 1, 2005 | 02:42 PM
None of those bolts that you posted, need Loctite.
One of the water pump bolts does however go right directly into the water jacket (lower one on the driver's side IIRC). Put sealer, NOT SILICONE, on those.
Old Nov 1, 2005 | 02:48 PM
Fire"Dutch"Bird's Avatar
Car: '88 Firebird Formula 350
Engine: 350 (5.7 TPI)
Transmission: auto 700R4
Axle/Gears: BW 9-bolt L.S.
Loctite is a brand, they have lots of different products, look at www.loctite.com.
xpndbl3
Brakes
35
Aug 15, 2011 01:46 PM
TransAm12sec
Jun 14, 2005 05:54 PM
JeffC1500TBI
Aug 16, 2004 04:55 AM
91NiteRida'
Mar 4, 2004 03:16 PM
91DropTopTA
Jun 7, 2003 08:51 PM
