rev limiter works great
Old Nov 1, 2005 | 10:12 PM
SS454's Avatar
Car: 1995 Z28 Conv
1995 camaro Z-28, auto-runs perfect, 90K miles.
Engine goes past rev limiter on 1-2 shift and 2-3 shift. I just had my tranny rebuilt by an experienced shop. no codes, Chevrolet can't find nothing.
Is it the ECM or ???
Old Nov 1, 2005 | 10:25 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
its an lt1, who cares
Old Nov 1, 2005 | 10:34 PM
SS454's Avatar
Car: 1995 Z28 Conv
The problem is that it totaly misses the shift and you have to back off the throttle for the shift. Anything under 4500 is ok, but over that it hits the rev limiter and doesn't shift.
Actually it goes right over the rev limiter. Something makes this car shift. ECM, valve body and ....?
Old Nov 1, 2005 | 10:44 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Locate a 4th gen site. This is a THIRD gen site.
Off hand I would think it's got to do with skip shift.
Old Nov 1, 2005 | 11:05 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Try the transmission board. Other than that the transmission is run by the ECM and shift solenoids in the transmission. Also check you VSS connection and transmission harness connector.
Old Nov 2, 2005 | 08:26 AM
Damon's Avatar
If you're running more than a ~3000 stall converter it's a real common problem on electronically controlled automatics in 4th gens. It'll often bounce off the rev limiter and not shift, or only shift after it's bounced off it a couple times. If that's not it, I'd have to suspect internal transmission problems.
You need a better tranny guy than me to help you any further.
Old Nov 2, 2005 | 12:06 PM
327???'s Avatar
Car: '82 Sport Coupe/'89 bird/'77 280z
Engine: 355/2.8/L28E(t)
Transmission: TH350/T5/4 spd
Axle/Gears: 3.73/3.42/3.54
camaroz28.com
lots of info there
MustangBeater20
Oct 29, 2022 09:20 PM
specialized
Jun 18, 2022 09:26 AM
theshackle
Sep 17, 2020 08:26 AM
Infested
May 22, 2018 11:56 PM
Thirim
Aug 13, 2015 03:09 PM
