weird timing on my stroker 383
Old Nov 2, 2005 | 08:42 PM
sleeper383's Avatar
Car: 1984 Camaro Z28
Engine: 5.0L
Transmission: Heavy duty TH700R4 B&M shifter
Axle/Gears: BorgWarner 9 bolt Ratio 3.45
I stroke my gm 4 bolt 350 crate engine a few month ago after
I put the engine in my car every thing goes normal but when i
decide to do a good timing i was very suprise by the reading 60 degre of initial advance.
i said to myself it's impossible the motor run great no pinging no
hard start no trouble on the road the damper is in the rigth place when the cylinder #1 is on compression at top dead center.
I bypass the MSD 6AL box and i change the distributor, same thing when i check with the timing ligth (i test it with another timing ligth).
I take my car to my Speed Shop were the engine was build and they check the set up and they told me that everthing seems
to be normal.
It's very frustrating because i can't go on the Dyno for tuning session etc.
Did anybody ever had this problem before and give some advice
please !!!
Old Nov 2, 2005 | 09:00 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
What dampner are you using? It must be hooped or you are using the wrong dampner/timing tab combo.
Old Nov 2, 2005 | 09:11 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Are you sure you're timing it off the right cylinder?
Old Nov 2, 2005 | 09:25 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
Yes, make sure its on the #1 plug wire.
if it wasnt on #1 slap yourself in the head
Old Nov 3, 2005 | 06:54 PM
sleeper383's Avatar
Engine: 5.0L
The Torsionnal Damper was bougth brand new from GM dealer a few years ago, it"s th 6.75" and the part number is 6272221
as you can see in the GM Performance Parts Catalog.
The Timing Tape was install by the Speed Shop they told me it
was install the correct way.
Old Nov 3, 2005 | 07:11 PM
sleeper383's Avatar
Engine: 5.0L
3 different mechanic check the timing with me and yes we all
know were is the #1 cylinder..., from front of the car when the
hood is open rigth side first cylinder !!!
Ghettobird52
Jul 5, 2024 11:18 PM
Cleotiz
Jan 6, 2018 08:56 PM
mhatfield 14
Oct 24, 2015 07:48 AM
Reddeath210
Oct 6, 2015 08:20 AM
sreZ28
Aug 14, 2015 07:48 PM
