oil leak
Old Nov 23, 2001 | 08:42 AM
84berlinettaV6's Avatar
oil leak
Whenever I stop my car after a trip it always smells like burning oil. After long trips I can see smoke coming up from my engine. I'm pretty sure it's an oil leak but what are the possible parts that need replaced? My bet is that it's a leaky valve cover thats letting oil leak down onto the block, but i can't really see or tell because the whole engine is dirty and oily. What else could it be?
Thanks for the help.
Old Nov 23, 2001 | 09:25 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
If you have a leaky valve cover, then try replacing the gaskets. You might have a leaky intake as well, which would require a gasket too. If it's your rear main leaking, that would be a pain in the butt.
"Putting any amount of money into a RICE BURNER is like wiping your a$$ with a turd. "
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat, just switched to 180* b/c of winter coming and going to college in the mts.
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
Old Nov 23, 2001 | 11:50 AM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Could be....
Dist O-ring (very common)
intake seal
valve cover
oil sending unit
rear main seal
front crank seal
You need to clean the engine a little and see if you can be more specific in the area of the leak.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
[This message has been edited by Engineboy (edited November 23, 2001).]
Old Nov 24, 2001 | 03:20 AM
89V6FBIRD's Avatar
Car: 1999 Pontiac Trans Am
Engine: LS1 - 346 ci
Distributor O-ring
https://www.thirdgen.org/messgboard/...ML/000888.html
Costs less than $2, make sure you have a timing light handy.
Stock 2.8 MPFI auto w/ Flowmaster 80 Series, More to come......
Pioneer DEH-11
Targa E-910 7-Band Equalizer w/ crossover
2x 10" Pioneer subs powered by 300 Watt Jensen amp
2- 6x9" Pioneer (rear)
More to come..... (hey, i dont got a job yet)
Old Nov 24, 2001 | 10:46 AM
SgtSkip's Avatar
Seems like every time I clean my engine it leaks oil more! Just last week I gave it a good washing and suddenly I was pouring oil out of the front seal. Turned out yesterday when I was replacing the seal that the timing chain gear on the cam wat beyond toast and I could just lift that chain right off. The oil was pouring out of the 1 inch crack that the chain had worn into the cover! Guess that will teach me to wash my engine!
85T/A 305/QJ work in progress.
[This message has been edited by SgtSkip (edited November 24, 2001).]
Old Nov 24, 2001 | 12:00 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
<font face="Verdana, Arial" size="2">Originally posted by SgtSkip:
</font>
Seen that before on SBCs, pretty common with high mileage engines..
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
"He can see air"
Old Nov 24, 2001 | 10:51 PM
SgtSkip's Avatar
I can beleive it after seeing what the gear was made of. I just turned over 214K on mine too...
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
bamaboy0323
Sep 12, 2015 07:14 PM
tgp1990
Sep 4, 2015 06:24 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
