AC delco rapid fires pregapped????
Old Nov 23, 2001 | 01:16 PM
breathment's Avatar
ok, according to their site, the rapid fires come pregapped, and they say that the package even says not to gap them. and the computer at autozone said they cam gapped, however mine were way off from the right gap, and i think the box even said to gap them. wuts up with ac delco??
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series Muffler added to Unkown CatBack, Ported Intake
http://www.geocities.com/david_angel_16
Old Nov 23, 2001 | 03:25 PM
SoCo80p's Avatar
they do pre gap them to the "most commonly used" gap they will be used for, BUT once in a while will be off, its allways a good idea to check them before you put them in.
Old Nov 24, 2001 | 11:10 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
the pre gapped part means they don't want you changing the gap. if you can read it not only says pre gapped, it also says "do not regap". this is for a reason. it's how they get away with the heat range capability and what they feel to be best for spark capability.
Old Nov 25, 2001 | 12:26 AM
breathment's Avatar
hower on the box it says gap vehical specs.. but the website and the comp at autozone say dont...
- David
Old Nov 25, 2001 | 01:34 AM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
You could have just saved yourself the time, and some money, if you would have just got the regular AC Delco plugs. The rapid fires will give you absolutely zero advantage over the regular plugs. It's just another way for AC Delco to make a few extra bucks.
1986 Trans AM
355 TPI
4 Wheel Disc Brakes
9 bolt Borg Warner Rear (2.77's....oh joy) :P
6" rods, approx. 9.7:1 Compression, Stock TPI (soon to be ported), 24#/hr LTI injectors (cleaned and flowmatched by Cruizin Performance), Hedman Shorty Headers, 3" exhaust with 80 series flowmaster, SBC 993 heads completely redone and modified for 1.6 RR, 1.52 RR (for now), Comp Cams XE262-14 TPI Cam, Holley AFPR, TPIS airfoil, MSD wires, MSD 6-AL Ignition, Hypertech 53,000 volt coil.
Track times to come.
RS Reaper
Oct 17, 2018 07:52 PM
Gunner242
Dec 25, 2015 04:49 PM
Reid Fleming
Oct 10, 2015 09:56 PM
meeklay812
Oct 1, 2015 03:46 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
