Non F-Body Question... PLEASE HELP :(
Old Nov 24, 2001 | 08:54 PM
Chuck Haynes's Avatar
I have a '93 Beretta with a 3.1L V6 and auto tranny. My radiator hose busted and my anti-freeze leaked out. My "Low Coolant" light came on (first time I have ever seen it on). I have replaced the hose and replaced the thermostat. Everything seems to be working fine now, except the "Low Coolant" light will NOT go away. I have unhooked the battery to try and reset it Still it remains ON Anyone have any ideas on this...
Any help would be apppreciated
-Thanks
Old Nov 24, 2001 | 09:15 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
I know this sounds like a dumb Q., but did you fill the radiator while it was running? Did you let it run about 15 min. with the cap off the rad.? Did you fill the reservoir?
I have a 95 Monte that did the same thing. Although the coolant was going into the oil pan on mine!!!!! The intake gasket gave way. I got the first "Low coolant" light when I was about 40 miles away from home. I filled the reservoir with water at a gas station. About 5 min later the light was back on again. So somehow it knows it's low.
I also had a hot-cold-hot-cold fluctuation from my heater on my car (the Camaro). The guys on here told me to let it run about 15-20 min with the rad. cap off to free the system of all air pockets. It worked.
Good luck,
AJ
Old Nov 24, 2001 | 09:28 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Make sure the overflow bottle is full.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
Old Nov 25, 2001 | 11:39 AM
AJ_92RS's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Engineboy:
</font>
That's what I meant by reservoir. Guess I used a 'too technical' word?
J/K
AJ
Old Nov 25, 2001 | 12:01 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
<font face="Verdana, Arial" size="2">Originally posted by AJ_92RS:
J/K
AJ
</font>
LOL, just re-confirming what you said.
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
"He can see air"
[This message has been edited by Engineboy (edited November 25, 2001).]
PurelyPMD
May 5, 2016 04:57 PM
Silver Spear
South East Region
18
Dec 4, 2015 09:59 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
Nervous2
Oct 8, 2015 10:53 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
