Speedo Inaccurate
Old Nov 4, 2005 | 01:04 AM
Eat_um_up's Avatar
Speedo Inaccurate
I have recently found that my speedometer reads about 15mph too slow. at 65mph it trads about 55. My car is an 82 pont T/A.
When i originally bought the car it had 14 inch rims on it. I put on the stcok 15 inch version of those rims. would that change result in the off readings im getting?. I would imagine it would effect it some but 15mph off seems a bit much to me.
But if the rim swap is the problem then what options do i have to make the speedometer read accurately?
Thanks,
James
Old Nov 4, 2005 | 02:08 AM
azvolfan's Avatar
Car: currently thirdgenless!!!
Do you have the stock rear end on the car?
azvolfan's Avatar
Also, have you or a previous owner replaced the transmission lately?
Old Nov 4, 2005 | 03:32 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The rim size alone won't affect the accuracy of the speedometer, but if you changed the overall tire height it could.
Old Nov 4, 2005 | 04:35 AM
Difflock's Avatar
Car: VIN=85 T/A, CAR=82/3 T/A gfx, go figure. She's a T/A anyway!
Engine: 5.0, Holley 600 cfm 4-barrel
Transmission: THM350 ??
I'm running 255/60 15's on the rear and the speedo reads low
Old Nov 4, 2005 | 05:02 AM
R1UK's Avatar
Car: Was 3rd Gen now MustangGT
Engine: 302
Axle/Gears: 3:73:1
Mine didnt work, but i knew with my new axle it would be wrong anyway.
Got a new cable [after cruise control removal] and still nothing, anyway removing the end of the gearbox to swap it is dead easy,
and i got Bowtie Overdrives to calculate the correct gears needed.
Working fine now, and reads spot on.
Old Nov 4, 2005 | 11:39 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Theirs a tech article on the tgo main page about the speedo gears. It even lists what gears you need for each rearend and their part numbers too!
Old Nov 5, 2005 | 12:31 AM
Eat_um_up's Avatar
Thanks for all the responses. I myself havent changed the rear end or tranny. But im like the 800 kabillionth owner on the car too. Somone probably changed teh gear ratios in the rear end or tranny at some point. Ill have to look into the tech artical with all the gear ratios. I wasnt aware there was one. Hopefully it will tell me how many spines i need to make this work.
Thanks again
GTAman
Jul 3, 2024 07:29 PM
Elephantismo
Feb 13, 2019 12:51 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
TrevinE
Sep 14, 2015 03:20 PM
86IROC112
Sep 11, 2015 04:04 PM
