"Heat Stove" removal
Old Nov 4, 2005 | 01:21 AM
MKnight's Avatar
Hey guys,
I have searched and found some threads on this topic but require some more precise insite. I have a Haynes manual for my car but need to get some opinions. Since I am using a K&N Air filter + Enclosure and not the stock closed system air box + snorkle I want to remove the heatstove thing cause it's just sitting there with the open pipe. Is this things going to be a bitch to remove myself? Can I do this without a hoist? I don't have jack stands either.
Old Nov 4, 2005 | 10:22 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
IIRC, the heat stove is tack welded around the manifold. If you wack it here and there, you might get it off.
JamesC
Old Nov 4, 2005 | 11:57 AM
Codename 47's Avatar
Car: 1986 Camaro Z28
Engine: 400
Axle/Gears: 10 bolt Posi 3.73
Whats the "heat stove"?
Old Nov 4, 2005 | 12:10 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
piece of tin around the manifold with a piece of hose running up to the air cleaner. lets the car breathe warmer air on cold days during startup.
Old Nov 4, 2005 | 12:13 PM
Engine: 400
Oh it's on the stock manifold? Gotcha, that's why I don't have it
Old Nov 4, 2005 | 05:18 PM
85cmroz28's Avatar
Car: 1985 Camaro Z/28
Engine: L69
Axle/Gears: One-Wheel-WOnder 3.08
I was able to pull mine off by hand.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Eric-86sc
Sep 7, 2015 02:10 PM
Stryker412
Sep 7, 2015 09:11 AM
