Greasing bolts for headers??
Car: 1988 SC Camaro
Engine: 305 TBI
Transmission: 700-R4
Is it a good idea to put some grease on bolts when installing headers in case they might need to come off and to keep them from rusting?...Is that a good idea to do for other things such as installing panhard-rods, LCA, ect...I've also heard of putting a silicone material on some bolts for certain applications as well....and advice or opinions about this? Thanks.
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
no such thing as grade 8 stainless bolts, AFAIK. A link to prove me wrong?
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I'm probably wrong then, I told the guy at the store I needed grade 8 or better stainless steel allen bolts for my headers and he just gave me some stainless steel ones.
Car: 1982 Trans-Am
had to double check this one, as I wasn't quite sure of myself.
Generally that's true, stainless is like grade 4ish. Allen bolts are usually like grade 9 bolts.
however, arp claims to make some stainless bolts 15% stronger then grade 8... I'd guess precipitation hardedning...
Aside from those ARP bolts, usually stainless is weaker, but doesn't rust.
Anyway, header bolts aren't exactly high stress, or dangerous (not like if it breaks you're dead), so their fine.
Car: '88 IROC-Z medium orange metallic
I just use some nickel anti seize, especially in aluminum heads. Never install any bolt dry. Always use some kind of lubricant or sealer.
ARP stuff is stronger b/c of the way they're made.
Originally posted by Rob Wade
Why bother? They always seem to fall out or come loose by themselves anyway!
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Originally posted by Dialed_In
Not if you re-torque them after they've been heat cycled a few times.
The constant heat cycling makes it nearly impossible to keep standard bolts torqued down for me, even with lock washers. Been thinking of getting a set of split-lock bolts. Not quite as strong but maybe theyll stay put.
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Anyone ever tried the ones with holes in the heads, where a piece of wire runs through the holes, from one bolt to the next? In theory the bolt won't turn because the wire keeps it in place. I just put a set on, like $15 - but haven't run the car yet to tell if they do any good. If I ever get my brakes and tranny working, I'll let ya know the results.
Car: 89 jaguar xjs convertable
Engine: 89 L98 5.7 TPI
Axle/Gears: 3.23 dana 44
Obviously I didn't have enough sarcasm dripping from my post. One of the biggest problems with header bolts is that 1 some headers have the holes slotted to allow you to install the bolt against a tube that turns right out of the flange. No surface area to grab onto and 2 the entire weight of the header (especially long tubes) is on the six header bolts and depending on how the exhaust is made if there is tension from the pipes below the headers simply flex and vibrate the bolts loose. Loose header bolts isn't as common on other engine headers because only sbc have the 1 2 1 exhaust port arrangement that causes the bolts to be so difficult to work with. I've installed tons of header sets and I've had good luck with blue (removeable) loctite.
Originally posted by dimented24x7
And retorque them again and again and again and again and again and again and again and again and again and again...
Car: 88 Camaro SC
Engine: SFI'd 350
Mine love to come loose no matter how tight they are. Another problem may be how poorly these aftermarket exhausts fit. The constant stresses on the headers themselves probably help the bolts to come loose.
LT1Formula
20
Nov 14, 2015 12:02 AM
hectre13
Sep 8, 2015 03:38 PM
Dialed_In
Aug 20, 2015 01:45 PM
