ignition coil trouble
Old Nov 26, 2001 | 07:21 AM
cael's Avatar
I'm about to get a ride out to work to replace my ignition coil for the *2nd* time. What causes them to go out? My car is an 89 RS (2.8L) if it makes a difference. In both instances it was working fine, I get in, drive somewhere, park it. I get back in, chuggachuggachugga but no vroom. I got a coworker to help me with a line tester so I know that power is going into the coil, but isn't making it to the wire that goes to the distributor. Any help would be greatly appreciated, I don't really want to have to stock up on those things :P
Old Nov 26, 2001 | 09:05 AM
PALM BEACH IROC-ER's Avatar
<font face="Verdana, Arial" size="2">Originally posted by cael:
I'm about to get a ride out to work to replace my ignition coil for the *2nd* time. What causes them to go out? My car is an 89 RS (2.8L) if it makes a difference. In both instances it was working fine, I get in, drive somewhere, park it. I get back in, chuggachuggachugga but no vroom. I got a coworker to help me with a line tester so I know that power is going into the coil, but isn't making it to the wire that goes to the distributor. Any help would be greatly appreciated, I don't really want to have to stock up on those things :P</font>
Check to see if there is power going to the coil after you shut down the motor and remove the key, a bad ignition switch can cause this problem which burns up the coil, as well as leaving the key on the "ON" position with out running the motor, to listen to the radio can burn it up too.
MM2Robinson
Oct 1, 2017 09:16 AM
RedLeader289
Sep 23, 2015 06:50 AM
Johnoooooo
Sep 22, 2015 08:55 AM
Jlanz55
Sep 6, 2015 03:05 PM
Jlanz55
Sep 6, 2015 02:35 PM
