the best timing belt for small block ?
Old Nov 25, 2001 | 04:41 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
anyone using a timing belt on a chevy smallblock? what brand and what is best?
1986 Iroc 305 small block chevy: ported heads, 1 3/4 slp headers, rpm intake, 1.6 roller rockers. looking for carb and cam.
Old Nov 25, 2001 | 05:29 PM
ede's Avatar
ede
jesel and i think comp have the ones that i've saw on cars at the race track. belts are pretty high dollar and very specialized parts and not needed for a street engine.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Nov 25, 2001 | 06:04 PM
kevinc's Avatar
Car: 1982 Z28
What ede said is the case, a belt setup won't make your 305 any faster...for what these cost the money is better spent elsewhere.
Go with a cam and a better carb as your sig says. Get a good double-roller chain setup (Cloyes) and you'll be happy.
1982 Z-28
See http://www.mycar.net/mafb/registry/detail.cfm?id=276 for details
Old Nov 25, 2001 | 09:16 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
so you guys have tried belts and didn't get any faster? did you change around the cam position to see if that gave better et's?
1986 Iroc 305 small block chevy: ported heads, 1 3/4 slp headers, rpm intake(ported), 1.6 roller rockers, performance valvejob, titanium retainers, compcams conical valvesprings looking for cam.
Old Nov 25, 2001 | 11:46 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You can do that with a chain. You don't have to spend $600 to discover that it was already fine the way it was.
What is it you are really asking?
ICON Motorsports
Old Nov 26, 2001 | 01:57 AM
poncho9789's Avatar
Another thing, a timing belt wont last as long on the street as on the track were you have limited time with the engine spinning.
Old Nov 26, 2001 | 02:45 AM
RedFirebird's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7L TPI (L98)
Transmission: 700RJunk
The money you'd have to spend to convert that could be better spent converting it to timing gears instead of timing chain.
Red '87Formula Firebird
-mostly stock 5.0L LG4 w/cowl induction setup borrowed from '83 TA and T5 tranny.
My newest Ride:
'85 Silver L98 Corvette w/4+3 manual tranny. not bad for $3500.
Old Nov 26, 2001 | 07:46 PM
kevinc's Avatar
Car: 1982 Z28
Nope, haven't tried a timing belt to see if it will lower my ET.
Also haven't tried carbon fiber valve covers, 8" exhaust tip, or a sticker with Calvin whizzing on a Ford emblem for the same reason.
If ya wanna make more power, move more air and fuel thru the engine.
1982 Z-28
jhawkeye
May 25, 2022 06:33 PM
9192camaro
16
Feb 3, 2019 12:21 AM
theshackle
Mar 5, 2017 06:37 PM
Fast355
Dec 2, 2016 06:33 PM
camaro71633
Sep 1, 2015 10:24 AM
