The shop doesn't know
Car: 1988 forumla 350
Engine: l98 350 tpi
Transmission: 700r4 2100 stall
I took my car into a repair shop for the transmisson.
They put a used tranny in it.
It still has shifting problems.
When the car warms up and at full throttle it will not shift into third gear.
They have had my car fo two weeks and they cant figure it out.
I think all i need is a tranny cooler.
The shop thinks it is the linkage.
what do you think?
what do you think?
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
They put a used ie worn out tranny in your car. Needs to be pulled and replaced with a new one. They can mess with the linkage till the cows come home, won't fix it. Takes all of 5 minutes to set the linkage. Cooler won't help at this point, should still work right without it. The stock one on the side of the rad is connected right? Aftermarket cooler would just make it live longer assuming you start out with a good trans.
Transmission: 4L80E/4L80E
Re: The shop doesn't know
You need another transmission, or this one needs to be rebuilt.
Of course, all of this assumes the TV cable is properly adjusted, which is part of the 5-minute adjustments Half mentioned. If it was improperly adjusted and driven that way, see paragraphs 1 & 2.
Engine: l98 350 tpi
No, it is different. Before it would not shift at all into second.
I have already adjusted the throttle valve cable.
That didnt do anything. I tell him what you guys said.
Engine: l98 350 tpi
He said he didnt see how it couild be the clutch pack
and that he is going to take it for a test drive so he could get it out of his shop.
Engine: SBC, LS-x
Don't let him move it till he fixes it. You paid for a working car and don't have one. Have him replace the defective tranny he bought. He should know better, you shouldn't have to ask. In this case, he's just trying to dump you.
Car: 88 formula WS6
Engine: 305 Lo3
Transmission: 700-R4
Your first clue is when he said "he wants to get it out of his shop". If it's not a trans. shop, they're just an R&R garage! The trans should be garanteed to the point that if it does'nt work you should be able to exchange it for another. It sounds to me like their trying to get out of replacing it and absorbing the labor cost to do it again. If they had done it right, a test drive would have shown that it wasn't working right, and you wouldn't have got the car back till it was. If they give you a bunch of lip about it SUE THEM! You can win in small claims for 10 bucks!
Engine: l98 350 tpi
i got my car back, they replaced the linkage and the governor and he throttle cable. I think they ment the tv cable.
i got on it from a stop twice and once from a punch and it shifted
every time.
i check my mileage
they drove it 8 miles so im not mad.
every time.
i check my mileage
Car: 88 formula WS6
Engine: 305 Lo3
Good deal! glad to hear all is good. I'm fixing to put a used steering box on my 88 form. tomorrow. I went to a wrecking yard that had boxes already pulled and they tried to BS me into buying a standard (3.5 turn lock to lock) for 50 bucks. When I first tried to tell them I needed one for my WS-6 form. they acted like they didn't know what I was talking about. I ended up finding one at a u-pull-it yard for 15 bucks and it only took 25 min to get it out!
not a bad price for a quick ratio 2.5 lock to lock huh?
Engine: l98 350 tpi
Thats awesome, some junk yards try to jiff people. I've been to quite a few and some times they over price stuff. I have been having problems finding firebirds with good parts on them.
Every junk yard i've been to crushes them.
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
