Bolt sizes for intake?
Old Nov 20, 2005 | 04:57 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I went to get stainless steel bolts and I'm having a problem. The bolt I brought to the hardware store (after removing it from my engine) is metric size 1.5. I thought the heads were 3/8" threads. Also, when I get new bolts, whatever size they are, do I put anything on the threads to seal them and keep them from coming loose? Thanks!
Old Nov 20, 2005 | 05:16 PM
ede's Avatar
ede
1.5 is the pitch not size, the bolts should be 3/8-16, you'd want to put some sort of non hardening sealer on them, like liquid teflon pipe sealer
Old Nov 20, 2005 | 05:37 PM
Car: 86 T/A
Engine: HSR 355
So I want 3/8" 16 which is in the SAE section? The only nut that fit over the bolt I pulled from my intake was from the metric bin which I thought was weird, I couldn't fit a 3/8" nut over it. I guess it was just the sealant on the threads. Also, I have black RTV, could I use that on the threads to lock them in rather than going out and buying some? Thanks for the info!
Old Nov 20, 2005 | 06:01 PM
ede's Avatar
ede
don't use RTV
Old Nov 20, 2005 | 06:28 PM
Vader's Avatar
Old Nov 20, 2005 | 06:49 PM
Car: 86 T/A
Engine: HSR 355
Haha, thanks for the close-ups!
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
toronto formula
Nov 10, 2015 06:17 AM
1985chevydude
Aug 22, 2015 05:36 AM
knight72
Aug 10, 2015 09:32 PM
