running terrible
Old Nov 26, 2001 | 07:00 PM
wa90formula350's Avatar
running terrible
I've got a 90 Formula 350, only 91k miles on it. Its running real bad, i've been through the boards and have done everything I can think of, new cap and rotor, cleaned the IAC, replaced the TPS, ran chevron injector cleaner through it, hi octane gas, reset the timing. I had just put on new Accel 300+ series spark plug wires and some of the platinum plugs, this was last year though and it has notbeen drven much so I dont remember if it ran like this before the plugs or not. Other than another set of not platimun plugs, I was told to see if the distibuter has alot of play in it. The car misses, hesitates right at 1700-1800 rpm and a couple days ago was runnin real bad motor was shaking a bit. Any other sugestions?
Rob
1990 Formula 350
Old Nov 27, 2001 | 04:11 PM
borgx's Avatar
Car: 1987 Pontiac Trans Am GTA
Transmission: WorldClass T5
Axle/Gears: 3.70
I have an 87 GTA with a 305 TPI. Same issue. It was my MAF sensor. Set me back quite a bit, but that was the problem. Replaced it and the car purrs now... I did all of the same things you did first...
James
1987 Pontiac Trans Am GTA - 305 TPI - 700R4
http://www.seven-of-nine.com/gta.htm
Old Nov 28, 2001 | 06:48 PM
Thanks for the help but I dont think 90's have a MAF sensor, I think its the other one, either way i'll check this out to make sure.
eightsixseven
Dec 16, 2024 01:50 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
perZ
Aug 21, 2015 05:51 PM
