rippin it out
Old Nov 24, 2001 | 06:57 PM
silentneko's Avatar
rippin it out
just wondering what are the consiquences of removing the smog equipment, I don't care about the 2hp I'll gain I just want more room to work, and how do you do it, what needs to be removed and what needs to be plugged.
neko
'87 trans am
car in the making
angelfire.com/fl2/neko
Old Nov 24, 2001 | 06:58 PM
silentneko's Avatar
this is on a computer controlled q-jet car
neko
'87 trans am
car in the making
Old Nov 24, 2001 | 10:05 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
it's real simple on a carbed car. does your car have the v belt?serpetine setup? or just one serpetine belt? if it the first one your in luck. all you have to do is remove the A.I.R. pump, the small belt for the pump, A.I.R. tubes, and the A.I.R. divertor valve(that black box thing with all those emissions hoses that go to it). you will have to plug the holes where the A.I.R. tubes used to go. you will need 8 1/2" pipe plugs for that. do not remove the air pump bracket as the fuel pump boss will be exposed through one of the threaded holes(oil will spill out).
86',88',89' IROC-Z, 350 TPI, 700-R4
94' Formula, LT1, 6spd
Old Nov 24, 2001 | 10:35 PM
silentneko's Avatar
ok what about the line that goes to the cat, will my cat burn up with no air to it, and does anyone have pics of this process
neko
'87 trans am
car in the making
Old Nov 24, 2001 | 11:22 PM
Inwo's Avatar
Car: 2007 Saturn Sky Redline
Engine: 2.0 turbo
Transmission: m5
Axle/Gears: 3.91 LSD
<font face="Verdana, Arial" size="2">Originally posted by silentneko:
</font>
Errr silly question but why would you keep your cat if you're getting rid of your emissions equipment ;-) Just gut the **** and worry not about it.
Old Nov 25, 2001 | 12:44 AM
silentneko's Avatar
I will be gutting the cat, but I figure it will be easier job to take out the emissions stuff, then later I will do the cat
neko
'87 trans am
car in the making
Old Nov 25, 2001 | 12:46 AM
silentneko's Avatar
and which holes will I be pluging with the 1/2" plugs, the small metal tubes on the headers?
neko
'87 trans am
car in the making
Old Nov 25, 2001 | 12:17 PM
silentneko's Avatar
ok, I went to home depot to get the plugs, but they had a few different ones to choose from, which one is the one I need, they had a threaded steal one, and a non treaded copper one I think they called it a fitting plug though. thanks
neko
'87 trans am
car in the making
Old Nov 25, 2001 | 12:37 PM
silentneko's Avatar
anyone, I would likr to do this today so please respond.
neko
'87 trans am
car in the making
Old Nov 25, 2001 | 03:23 PM
Car: 1988 IROC-Z
i used the 1/2" steel ones but got mine at autozone. you will use those to plug up the holes where the little air tubes used to go into on the exhaust manifolds or headers. (whichever you own)
Old Nov 28, 2001 | 09:59 AM
silentneko's Avatar
is the tread 1/2 inch, cause when I went to home depot the guy showed my plugs but they seemed to be like 3/4 with a 1/2 wrench end. do they sell the plugs at discount auto parts. so all I have to do is plug those 8 little holes and the rest of the hoses I just rip out? and about how long does this whole thing take
Old Nov 28, 2001 | 07:53 PM
89 rs305's Avatar
I would like to remove the air pump, cat, and the egr setup. I have the tbi and one belt for everything. Will this cause any problems? I want to put regular headers on the car instead of the ones with the air tubes.
rippin ron
Jul 19, 2013 06:55 PM
topless87
Feb 7, 2013 11:44 AM
HotRodkid87
Jun 11, 2012 04:04 PM
sabresfan
Members Camaros
20
Sep 3, 2011 08:31 PM
Matt1821
Nov 17, 2010 06:48 PM
