The Money Pit
Old Nov 10, 2005 | 09:01 PM
cheese_kake's Avatar
Car: 1992 Camaro Z28
Engine: 5.7 LT1
Transmission: 4L60
Axle/Gears: 3.23's
The Money Pit
My car just keeps sucking me dry of my money. After all my last repairs I had my car running better than ever. Then one day while pulling out on the road pretty fast, getting on it hard , I heard this noise. After I reached my destination I free revved it with the hood open at the TB and heard a knock when it would come off the rev. Its a main bearing or rod bearing I think. Because you can't hear it at the valve covers but you can hear it real good from under the car at the oil pan, I also have bad oil pressure and I hooked up a manual gauge and Im only getting 10psi at idle and I used to get 30psi. This lack of pressure Im almost positive is because when I replaced the intake manifold I cleaned a bunch of sludge out of the lifter valley and I was careful not to let anything fall into the oil pan , but it seems that some did because now my oil pump screen is blocked and now Im getting crap oil pressure.
Old Nov 10, 2005 | 10:01 PM
chevymetal's Avatar
Car: 1985 Chevrolet Camaro IROC-Z28
But if you fix it all now, you'll basically have a brand new car when you're done!
Old Nov 10, 2005 | 10:24 PM
Engine: 5.7 LT1
Transmission: 4L60
Axle/Gears: 3.23's
I've basically accepted that It wont be done till everything is replaced.
Old Nov 10, 2005 | 11:53 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Originally posted by cheese_kake
I've accepted that It wont be done till everything is replaced.
You've basically just defined hot-rodding
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Linson
Oct 1, 2015 09:50 PM
mfp189
Sep 27, 2015 09:25 AM
