starter woes
Car: 85 Camaro
Engine: 400
Axle/Gears: 3.08 10 bolt
starter woes
A friend of mine is having problems with starters on a 305. The snout that protects the gear that turns the flywheel keeps breaking. That's about all I know, figure I'd try to help him out. Any thoughts would be appreciated. Thanks.
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Was it a new starter? Were shims included? If so, you may have to use those.
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Check the clearance between the flywheel and starter teeth with a paperclip. If you cant get a paperclip between them you need a shim or 2 or whatever it takes to get the thing in there.
Gunner242
Dec 25, 2015 04:49 PM
