Starter problem I think.....any help?
Old Nov 12, 2005 | 03:56 PM
ammoblows's Avatar
Car: 1982 Z28 Indy Pace Car
Engine: 350 HO 4bbl
Transmission: TH350
Switched from a cfi 305 to a 600 cfm 350 HO, got the motor going with the old starter and alt. Got the TV cable adjusted after about two weeks, finally figured out the fuel pump and line issues! Drove the car to work and back for about a week, battery would not hold a charge so I bought a new one...it started to die after a few days so replaced the the alt, problem gone. Went out after work thursday to go home, started car and it sounded as if a belt was spinning then it stopped after about ten seconds, thought I lost a belt opened the hood and all was good. I got home and turned the car off, it refused to turn off. All I could hear is the starter turning with the key off!! Do you think I need to replace the starter or maybe the wiring from the key. I just replaced the ignition lock cylinder today with a new one and that did not fix it. Can only think of the wiring or the starter itself. Please help!
Old Nov 12, 2005 | 04:03 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Possibly a stuck solienoid on the starter...
Spyder_TheGamer
Dec 25, 2015 05:07 PM
5spdcamaro
Aug 28, 2015 02:12 AM
92camaroJoe
Aug 13, 2015 06:07 AM
milk
Aug 10, 2015 06:26 PM
