Catalytic Converter problem
Old Jul 31, 2000 | 02:34 PM
iceman's Avatar
My car has been down on power, sucking gas like there is no tomorrow, overheating, and backfiring like mad lately. I finally traced the problem back to the CAT. There is an air line (I think that it may recirculate exhaust) that comes off of the CAT and connects to the engine somewhere. Well, this line is broken on my car. The little elbow like piece that comes out of the CAT is not broken, it is further up the line. Now, I need a way to fix/replace it. Has anyone ever had to do anything like this? Who would sell the entire line? I thought about finding some tubing that I could slip over both of the broken ends and clamping it down, but then I worry that it will cause the line to break somewhere else. Any help would be greatly appreciated!
Old Jul 31, 2000 | 02:37 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Sorry, but that broken line has absolutely nothing to do with your poor running. Thats an AIR injection line into your cat. You can fix it the way you described by simply putting a hose over it asnd clamping it down. If it's broken really close to the cat you'll need to use green hose. If not, any old heater hose should be fine.
BUt like i said, this has nothing to do with how your car is running.
ed
Old Jul 31, 2000 | 05:20 PM
dtpmike's Avatar
just gut out your cat, then you wont need the air pipe. You will gain HP and your car will gain intimidation factor.
Old Aug 1, 2000 | 05:59 PM
iceman's Avatar
Okay, the air pipe was only a fraction of the problem. The damn CAT was clogged. Tore that sucker off, cleaned it out and slapped it back on - problem solved! How does that CAT get clogged? Is my engine running like crap and I just don't know it? When I first got the car, I gutted the CAT. Then emission time came around and I had to replace it. Now it gets clogged again. What is the deal?
Old Aug 1, 2000 | 07:08 PM
Guest
Guest
Posts: n/a
Means your car is running WAY too rich.
Old Nov 29, 2001 | 11:24 AM
FiReBReTHa's Avatar
if im too poor to afford a new cat right now, can i weld a piece of tube there, and then do what with the air tube until im ready to purchase my high flow catco???
thanx
91 FireBird 305 V-8
Edelbrock Catback, Custom Alarm. Fourth Gen Console. i have six cupholders. all for starbucks!
Go|)Created The Earth, And Then Turned Up The Bass.
Here's My Audio Install!
"Honda's FOR ME TO POOP ON!" -Triumph...
Old Nov 29, 2001 | 03:03 PM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
You should be able to get some rubber hose to conect both ends of your broken tube.
Assuming you didn't remove any emissions stuff that tube allows air from the AIR pump to go to your cat in order to help burn exhaust gases. Not enough air...unburned exhaust...eventually clogged cat. Make sure your AIR diverter valve is working (just follow the tube back to the engine).
If everything works, put the cat back on, check/replace your O2 sensor, get a tune-up if its been awhile, and you should be fine.
This is assuming emissions are an issue.
ORIGINAL OWNER
92 Camaro RS, LO3, 5-spd, T-tops
Performance:
K&N Open Air Filter, Partial TBI mods, Edelbrock performer TBI intake, Fastchip Prom, Timing +4 degrees, Centerforce clutch, Xact 8mm wires, SLP 1 3/4" Headers (coated), Flowmaster Catback Exhaust, Richmond 3:42 gears, Torsen HD Posi
Sights & Sounds:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers. Spectre valve covers and accessories, Z28 grille w/aftermarket lights, MacEwen whiteface gauges
NEXT UP: the rest of the TBI mods & Suspension upgrades
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
theshackle
Mar 5, 2017 06:37 PM
dyeager535
Aug 28, 2015 08:10 AM
gta power
Aug 13, 2015 06:15 AM
