Different starters ?
Hey everyone. My starter is gone (solenoid is sticking and not engaging) and I was told that 5 speed starters and automatic starters are different. I have an auto starter in there. It was rather easy to put the bellhousing over it, but I'm told it wont be so easy when I take it off and have to replace it. So.. do 5 speed cars really use a different starter ??
1992 Z28 5.7 TPI
ZZ4 longblock
Harland Sharp roller rockers
Accel base and SLP siamesed runners,
52MM SLP Throttle Body
Hooker Headers & Flowmaster catback
MSD6A ignition
aluminum driveshaft
World Class 5-speed
1992 Z28 5.7 TPI
ZZ4 longblock
MSD6A ignition
aluminum driveshaft
World Class 5-speed
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
From 90 or 91 on, 5speed 305s had a smaller starter that uses rare earth magnets. It fits better with full length headers I know for sure. It also has the parallel bolt holes. (but so do most 350s-my 400block did not).
Car: 91 camaro
Engine: 383
I checked on this at work (parts store) and it turns out that the 305 manual and auto both use the same starter. I'd heard a similar rumor, but apparently it's not true in all cases. Interestingly enough, the 305 and 350 use different starters, although the only visible difference I could find was the size of the large bolt that the power lead hooks to on the solenoid. 305 and 350 have the same flexplate, so there's no difference on the spacing or number of teeth or anything. Maybe the 350 starter has more torque?
This is all for 91-92 f-body, mind you.
91 Z28
Come see The Vicious...
91 Z28
when i swapped my 305 for a 355...i had to use a 5spd starter do to the nose for the gear to engage was too big on an automatic starter for that year engine....
84z28HO
355
open element/k&n
m5/hurst billet plus shifter
83 z28 fiberglass hood
10bolt w/3:42posi
gm aluminum driveshaft
performer intake
performer 600cfm carb
accel 8mm wires
adjustable thermostat switch
160 stat
gta rims
gts blackouts
s.s rear control arms
s.s panhard rod
s.s subframe connectors
98 camaro rear springs,shocks
98 z28 leather seats
95 camaro rear view mirror
"wonderbar"
4th gen z28 tips
14.3@95mph
http://www.geocities.com/toosloz/84camaroz28.html
84z28HO
355
open element/k&n
10bolt w/3:42posi
performer intake
accel 8mm wires
160 stat
gta rims
gts blackouts
s.s panhard rod
"wonderbar"
4th gen z28 tips
14.3@95mph
Gunner242
Dec 25, 2015 04:49 PM
