Timing brackets
Old Nov 30, 2001 | 10:12 PM
DKING's Avatar
Timing brackets
This may sound like a stupid question but on my 305 there is no timing timing bracket bolted to my engine. Does it matter which side that I bolt it to? My camaro has been modified and it's easier to bolt it to the passengers side of the block. Is the cool?
Old Dec 1, 2001 | 02:27 AM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Look straight down/dead center between the water pump and the timing cover.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
Old Dec 1, 2001 | 09:36 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
You cannot put it wherever you want. It needs to go on the upper driver side of the timing cover.
1987 GTA L98 MD8
355, TFS Heads, LT4 Hot Cam
My GTA
The Minnesota F-body Club
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Jan 9, 2020 08:29 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
jahblah
Aug 12, 2015 05:54 PM
