what are some good things to do for a good tune up.
Old Dec 1, 2001 | 06:05 PM
FastAndFurious's Avatar
i recently bought a 92 camaro and it rides pretty tight i was just curious is to wha i could do to give it a good tune up so that i notice a bit of difference.
Old Dec 1, 2001 | 06:11 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I'm not sure of everything involved in a complete tune up, but new plugs/wires, cap and rotor, maybe a radiator flush. Change the oil and tranny fluid. Change your belts, they don't cost much, but they could break an a bad time.
2 Tickets to game= $250
Gas= $20
Sitting 20ft. from MJ= Priceless
'86 IROC T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK HEADERS Hooker CatBack
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat, just switched to 180* b/c of winter coming and going to college in the mts.
3:73 Posi Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
Old Dec 1, 2001 | 06:55 PM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
What Shields said.
Definitely change the fuel filter; since it's a new car you never know how many miles it's been there for. Also do a visual check on the air filter, it might need changing too. As for the belt, if it doesn't have any cracks don't bother changing it.
91 Z28
Come see The Vicious...
[This message has been edited by ViciousZ (edited December 01, 2001).]
Old Dec 1, 2001 | 08:07 PM
im going to change the plugs wires and rotor soon im just curious on which is best to buy (maybe to upgrade what i have) and if i can get the wires in different colors other than black or gray. just to dress the engine up a bit.
Old Dec 1, 2001 | 08:36 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
I've got BLUE Moroso 8mm on my car. Not that you will feel a difference (unless your car's wires are shot). Get some AC Delco plugs (don't fall victim to ****fires). I use a special cap so that all even plug wires exit the passenger side and all odd wires exit the drivers side (looks neat) but I used to use OEM (AC Delco) cap and rotor. Good pieces.
Probably could use a new O2 sensor (spend the money and get a Delco sensor, most aftermarket sensors are pure JUNK) and a PCV valve and stuff.
If you live in Southeastern US, check us out!
South East Thirdgen
1987 Trans Am 305
14.88 @ 92.81
[This message has been edited by GMTech (edited December 01, 2001).]
Old Dec 1, 2001 | 09:01 PM
MetKiss316's Avatar
Maybe somebody could type out a list of a "full tuneup." This is what I know:
Spark Plugs
Spark Plug Wires
Fuel Filter
Oil Change
What else? Im learning stuff...what exactly is a "cap and rotor" and other stuff.
1987 Camaro Sport Coupe 305 V8 LG4-rebuilt-All Stock.
Future Mods: Flowmaster American Thunder 3 in. Cat-back, Catco High Flow Catalytic Converter, Hooker Super Comp Shorty Headers Jet Hot coated, K&N Air Cleaner, CompCam 264H, White Paint, IROC wheels, Alpine CDM-7871 CD player, Polk Audio speakers, Grant GT Rally Steering wheel,New Fuel Pump, Ground Effects, B&M Megashifter
Old Dec 1, 2001 | 10:09 PM
Azure's Avatar
From: "No one cares if you're in before the lock!" - Best quote ever.
https://www.thirdgen.org/messgboard/...ML/002983.html
Here's the stuff.......
Old Dec 1, 2001 | 10:20 PM
Vader's Avatar
And this one for a quick overview: https://www.thirdgen.org/messgboard/...ML/004797.html
Later,
Vader
If you want to beat the World, it might reach up and pull you down...
Adobe Acrobat Reader
Old Dec 1, 2001 | 10:21 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
<font face="Verdana, Arial" size="2">Originally posted by GMTech:
I use a special cap so that all even plug wires exit the passenger side and all odd wires exit the drivers side (looks neat)</font>
So are you using an HV Vortec style cap, or????
1987 GTA L98 MD8
355, TFS Heads, LT4 Hot Cam
My GTA
The Minnesota F-body Club
Old Dec 2, 2001 | 08:09 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
No, its the large Coil-in-cap HEI. Its made by Crossfire, part # 4512-B-011
It looks like a stock cap except the wire routing. Its hard to see w/ the Accel coil on it, but it looks stock.
South East Thirdgen
1987 Trans Am 305
14.88 @ 92.81
[This message has been edited by GMTech (edited December 02, 2001).]
Ghettobird52
Jul 5, 2024 11:18 PM
customblackbird
Aug 15, 2021 10:16 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
camaro71633
Sep 1, 2015 10:24 AM
Bob88GTA
Aug 18, 2015 03:31 PM
