Jet hot coating
Car: 71 Nova
Engine: Superramed 383, Topline heads
Axle/Gears: 8.2 posi 3.08
Jet hot coating
I have a set of aluminum pulleys I got dirt cheap. I heard they tend to wear out quicker since they are aluminum. Would having them ceramic coated make them last longer?
Transmission: 4L80E/4L80E
Probably.
Hard anodize would probably works as well or better, and would probably be cheaper.
Car: 71 Nova
Could you give me any info on hard anodizing? Is this something I could do myself?
Not that I've heard. Most any plating shop could handle it, I would think.
http://www.engineersedge.com/mil_a_8625.htm
If you happen to live in Lincoln, NE: http://www.lincolnplating.com/anodize-hard.html
Car: 71 Nova
Here are some recipes.
http://www.hbsequipment.com/html/pla...izingdata.html
The voltage im not sure about, but i could maintain any temperature easily with dry ice. I have access to all ingredients as well as a lab enviroment.
