Ok, new problem
Old Dec 2, 2001 | 03:42 PM
BitchinCamaro's Avatar
Ok, new problem
I got the timing set at about 6*, but the car doesn't want to idle. I can rev it and it feels strong. If I rev and let off the rpms just fall down and the engine doesn't try and catch itself. If I play with the throttle I can get it to kinda of hold around 1000-1500 rpms, but when I let off, it just kinda of stumbles and shuts down. I tried setting the IAC but couldn't get a good enough idle to do it. Thank you.
Old Dec 2, 2001 | 03:55 PM
Vader's Avatar
BC,
What engine/year/car is this?
Did you disconnect the EST bypass to set the base timing then reconnect it?
Later,
Vader
If you want to beat the World, it might reach up and pull you down...
Adobe Acrobat Reader
Old Dec 2, 2001 | 04:36 PM
Its an '89 TPI 350, and yes I did disconnect the EST, set the timming and reconnected it.
Old Dec 2, 2001 | 04:49 PM
Z28fromItaly's Avatar
Looks like a vacuum leak somewhere
Old Dec 2, 2001 | 04:57 PM
Vader's Avatar
You can remove the IAC unit, clean the air passages and pintle, then work the IAC pintle all the way back into the unit before installing it. That should give you a pretty high idle when you first start the engine, and if the IAC steps back down to a more normal idle after satarting, you can assume that is is at least working.
While cleaning the IAC passages, cleaning the TB bores might help too.
Later,
Vader
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
