383 stroker one piece rear main seal
Old Nov 18, 2005 | 03:36 PM
rew's Avatar
rew
Car: 85 trans am
Engine: 383 stroker
ok i built a 383 stoker with a one piece rear main seal. the crank is not internally balanced. oviously the 400 flywheel wont bolt on so i have to use the 350 flywheel. i tried a few balancing options: 350 balancer/flywheel, 400 balancer/350 flywheel, the flywheel still has the weight on it. i also tried the balancers with the weight removed and still no luck of a balanced engine. my question is which balancer do i have to use??? and what do i have to balance the flywheel?? i rewelded the weight back on. what else to i have to do? i talked with some machine shop guys and they said i have to add more weight with the existing one thats on there. is that true? where do i put it on the flywheel? i just need to know how to solve my problem because im all out ideas.
Old Nov 18, 2005 | 03:48 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Nevermind, thought you said it was internally balanced.
How are you spinning it up to balance it, anyway?
mhatfield 14
Oct 24, 2015 07:48 AM
Reddeath210
Oct 6, 2015 08:20 AM
Reborn756
Sep 4, 2015 03:42 AM
LT1Formula
Aug 20, 2015 09:36 PM
86White_T/A305
Aug 17, 2015 12:16 AM
